Renard PX1 Pixel Controller
General
Features
 - Some Design Details:
| Total Number of Pixels Capable  for a given Baud Rate/Refresh Interval* in a Renard Network per Comm Port  | |||
| 100 ms | 50 ms | 25 ms | |
| 230400* | 764 | 382 | 191 |
| 115200 | 382 | 191 | 95 |
| 57600 | 191 | 95 | 47 |
| 38400 | 127 | 63 | 31 |
| 19200 | 63 | 31 | 15 |
*A new Vixen plugin is required to support higher baudrates.
Typical Pixels require power injection every 50 pixels.  The Renard PX1 only supports up to 50 Pixels directly powered from the controller.  If you use more then 50 Pixels (or if the cable is too long for the wire gauge), you must provide an off-board fused power source to provide Power Injection downstream.
PCB Layout
BOM - Bill Of Materials
The Mouser Project BOM can be found here.  On 6/1/13 the price for a single BOM was $16.40 from Mouser.
Assembly Instructions
 - Configure Jumpers
 - □ Install Resistors
 - □ R4 - 330 ohm bussed resistor. Note that this resistor is polarized and only can go in one way.  The dot on the package denotes pin1.
 - □ Install Capacitors
 - □ Install Diodes
- □ D1 - 1N5239B diode.  Diodes are polarized and they have to be installed with the correct orientation.  The end of the diode with the band goes towards the bottom of the board and in the square hole.
 - □ Install IC Sockets
- □ U1 - 8 pin socket.  The socket has a notch on one end and the notch must be installed to match the direction on the silkscreen.
The notch faces right.
 - □ U2 - 14 pin socket.  The socket has a notch on one end and the notch must be installed to match the direction on the silkscreen.
The Notch faces right.
 - □ Install LEDs
- □ D3,D4 - Yellow LED.  LEDs are polarized and they have to be installed with the correct orientation.  The anode side of the LED with the longer leg goes in the top round hole.
 - □ Install Voltage Regulator
 - □ Install Fuse Holder
 - □ Install Connectors
 - □ Install RJ45 Jacks
 - □ Install Fuse
 - □ Install ICs
Configure Jumpers
Install a shunt (jumper) across Pin 1 and Pin2 if you are using RS232 Input to the controller.  Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input.
J3- 2x5 Options Connector
This connector is used to set various special options.   The default is no jumpers used on this header.
If and only if you are using WS2801 pixels and have issues with stray flashing on older pixels, you can put a single jumper on the two most left pins of the header (up and down) and restart the PX1.  This option uses a slightly different timing that will only work with WS2801 pixels.   Generally most WS2801 pixels will not need this jumper.
Do not install any jumper here until instructed to do so.  This jumper is only used to change the settings in a PX1 by using a specially formatted vixen or other control software data stream.  See Configuring the Settings via a Renard Data Stream
J7- Voltage Selector
This 3 pin jumper is used to select the power source of the control circuit on the board.  This jumper must be set to match the voltage requirements of your pixels.  If the power input to the board is 12VDC, then jumper must be placed on the two left pins.  If the power input to the board is 5VDC, then the jumper must be placed on the right two pins.
IT IS CRITICAL THAT YOU CONNECT THE CORRECT VOLTAGE TO THE UNIT AND HAVE THE CORRECT VOLTAGE INPUT SETTINGS!  YOU MAY DAMAGE THE CONTROLLER AND PIXELS IF YOU CONNECT THE WRONG VOLTAGE OR HAVE THE WRONG VOLTAGE SETTINGS ON J7!
Program PIC
J2-ICSP Programming Header
J2 is the 6 pin header located in the top center of the board that allows In Circuit Serial Programming.  J2 allows the PIC microprocessor to be programmed in place on the board by directly connecting a PICKIT2 or PICKIT3 programer.  It eliminates the need to remove the PIC from the PCB to program or modify the programming in the PIC.
| Pin # | ||
| Signal | ||
| 1 | VPP/MCLR | |
| 2 | VDD Target | |
| 3 | VSS (Ground) | |
| 4 | ICSPDAT/PGD | |
| 5 | ICSPCLK/PGC | |
| 6 | N/C | |
Connections
The two RJ45 Connectors J5&J6 near the bottom left of the board are used to bring data signals to and from the board.  J5 on the left side is the signal input from the PC or previous Renard controller.  J6 on the right side is the output to be daisy-chained to the next Renard controller.  These connections are the standard Renard daisy chain configurations.  The pins on these connectors are used as follows:
| Pin # | RJ45 Connector | |
| J5 Input | J6 Output | |
| 1,2 | GND | GND |
| 3 | NC | NC |
| 6,7,8 | NC | NC |
J8-Pixel Power Input
J8 is the 2 pin terminal block located at the bottom center of the PCB.  The Renard PX1 can be powered by either 5 or 12VDC (depending on pixel type).  If you are using 5VDC, you can omit the voltage regulator and set Jumper J7 to the two right pins (5v position).If you are using 12VDC, then you must use the on board voltage regulator and set Jumper J7 to the two left pins (12v position). IT IS CRITICAL THAT YOU CONNECT THE CORRECT VOLTAGE TO THE UNIT AND HAVE THE CORRECT VOLTAGE INPUT SETTINGS!  YOU MAY DAMAGE THE CONTROLLER AND PIXELS IF YOU CONNECT THE WRONG VOLTAGE OR HAVE THE WRONG VOLTAGE SETTINGS ON J7!
| J8 Power Input | ||
| Pin # | ||
| Voltage | ||
J9 - Output to Pixels
J9 is located along the bottom right side of the board and is a 4 pin Euro style plugable connector used to connect to the Pixels.  Pin 1 of the connector is on the left side and is marked by the square hole on the silkscreen.  You must wire the plug onto your pixel string according to the correct wire color code for your pixels.  Please check with your vendor to confirm the color code of the various wires and how to determine the input end of your pixel string. Some examples of the various wiring color codes can be found here.  Another common choice is to wire a waterproof connector to the euro plug and use waterproof connections to their pixels. Note that WS2811 pixels only have 3 wires( V+, Data, GND) and they do not require a Clock wire.
| Pin # | ||
| Signal | ||
| 1 | GND (V-) | |
| 2 | Clock (C) | |
| 3 | Data (D) | |
| 4 | V+ | |
Indicator LEDs
Attn
ON when J4 jumper for Renard Data Stream Configuration is in place.
Rx
FE
Pwr
- Baud Rate:
- Find the line in the code that says " #define BAUDRATE_INDEX_DEFAULT BAUDRATE_115200"  and adjust the baudrate to one of the following values:
- RGB Order:
 - Grouping:
- Choose your start address
 - Example:
- If start address = 1
- Channel 1 = 0
 - Channel 2 = 1
 - If start address = 45
- Channel 1 = “0”
 - Channel 2 = “45”
 - If start address = 257
- Channel 1 = 1
 - Channel 2 = 1
 - Power off the PX1, install the jumper J4 on the PX1 then power ON the PX1 (the ATTN LED should be lit) and set up Vixen to send out the Renard data packets with the new address or configuration change.
PX1 Programming Packet Format
| Packet (Channel) | ||
| Value | Default | |
| 3 | Baudrate Code | 4 |
| 4 | Group Size | 1 |
| 5 | Group Count | 50 |
| 6 | RGB Order Code | 0 |
Start Address Packet Format
| Start Address | Packet 1 MSB (Channel 1)  |
Packet 2 LSB (Channel 2)  | ||||
Baud Rate Packet Format
| Baud Rate | ||
| Baud Rate Code Packet 3 (Channel 3)  | ||
| 19200 | 0 | |
| 38400 | 1 | |
| 57600 | 2 | |
| 76800 | 3 | |
| 115200 | 4 (Default) | |
| 230400 | 5 | |
| 460800 | 6 | |
Color Packet Format
| Color Order | ||
| RGB Code Packet 6 (Channel 6)  | ||
| RGB | 0 (Default) | |
| RBG | 1 | |
| GRB | 2 | |
| GBR | 3 | |
| BRG | 4 | |
| BGR | 5 | |
Enclosure
The Renard PX1 pixel controller can be mounted in the users choice of enclosures.  One common choice is the TA-200 enclosure.
The PX1 has three screw holes that line up perfectly with the plastic standoffs in the inside of the TA-200 enclosure.
Initial Thread
Beta Test Thread
Group Buy Interest Thread
Different Styles of Pixels
Waterproofing Pixels
