Vastelec FM02
You can also receive warranty service from the units purchased directly from www.radiant-holidays (former WLC )ventures.
Pictures of FM02's in enclosures
Each FM02 installation is unique !
A gallery of pictures and 'how to build notes' showing various FM02 installations is available.
Do you have a HUM ?
Audio
Schematic and PCB layout
Detailed Board Dimensions
Antenna
The FM02 has an antenna connection that will look a bit unusual to most folks.
The converter shown below will correctly hook to the FM02. SMA is the smaller gold colored part of the connector.
How to Make a Dipole Antenna
More recently, DIYC member Jhinkle published a paper for an antenna design that is easier to build with very good transmission characteristics.
Here is the link to a posting on the subject.
DIYC discussion thread
You can go directly to the excellent design and build paper at this link:
pdf paper for a ground plane antenna
What Frequency to Use
This is real simple, go to this website and find a frequency that is unused.
If there are no unused frequency's, then pick one that is not very powerful and
get your radio out and check it out. If you can't pick up any radio stations at your house, odds
are no one will complain when you start broadcasting on that frequency.
NOTE: There are seasonal radio stations. A open frequency in June may be used in December. You should plan accordingly.
The may also be available at diyledexpress
RDS hookup information
Pira Mini-RDS hookup diagram:
Additional Modifications
Why you should care about the transmitting power of your transmitter (FCC regulations)
PART15:
Please note: This should be considered an advanced modification. There are hundreds of FM02 in use by the DIYC community and the vast majority use them without this modification.
