Vastelec V-FTM212R
The FM Transmitter with built-in RDS and USB connectivity
The FM02 is a two board FM transmitter.  It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.  It comes just as shown in the picture above.
