16 Channel Renard with SSR Assembly Instructions
- Assembly Time: 2 hours
 - Skill Level: Medium
Disclaimer
THIS FILE IS DISTRIBUTED IN THE HOPE THAT IT WILL BE USEFUL, BUT WITHOUT ANY WARRANTY; WITHOUT EVEN THE IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
Reference Material
Tools
- Bench Soldering Iron
 - Silver Solder
 - Flat cut dykes
 - Desoldering bulb
Other Requirements
- You will need an RS232 to RS485 converter. I would suggest EBAY
Related Documents/Links
- RS485 Converter from Ebay
 - Parts List
 - Theory of Operations
 - Image of Board
 - Top of PCB
 - Botton of PCB
 - Silk Screen
 - Latest PIC Code
Build Steps
Options
240 or 24 volt Conversion
The original controller was designed for operation on 110VAC and many of the parts were specified for 110V. The board will operate at other voltages, however a number of changes need to be made.
The first decision to be made is what voltage you want to switch. The triacs are responsible for switching the primary voltage. The is no reason that the primary voltage for the TRIACs could not be 240VAC or 24VAC, however the circuit will need to be modified.
One of the major changes is the ZC detect section of the controller. The original circuit specified a H11AA1 for the optoisolator, with two 15k ohm 1watt resistors for current limiting. Details on the H11AA1 can be found here
I understand that the 15kΩ values are calculated as follows:
I(fwd-peak) = 5mA
V(rms) = 110 VAC RMS
V (peak) = V(rms) * 1.41 = 150VAC
R = V(peak) / I (fwd-peak) = 150V / 0.005 A = 30k ohm Two resistors of 15 k each for a total of 30k.
P = I(peak)(squared) * R = 0.005 * .005 * 15000 / 2 = 0.2W per resistor.
24VAC switching.
Parts Required and changes.
Gate Resistors - The original value for the gate resistors (item 7) was 180 ohms. For 24VAC operation, the gate resistors need to be changed to 33 ohms.
H11AA1 limiting resistors - These will need to be changed to 3.3k 1/4 watt.
240VAC switching.
Gate Resistors - The original value for the gate resistors (item 7) was 180 ohms. For 240VAC operation, the gate resistors need to be changed to 360 ohms.
H11AA1 limiting resistors - I am going to make a suggestion for the board to operate on 240VAC that will require a number of physical and electrical changes to the ZC circuit on the controller. This modification is designed to use a low voltage transformer to derive the ZC signal from, instead of the 240VAC Hot rail.
1. Fit two R18s to the PCB. Now that the PCB has been modified, you need to fit two new R18s, appropriate for the ZC voltage the H1AA1 will be sensing.
2. Cutting a track. Looking at the copper side of the PCB, you will notice a small track common from the HOT rail to the inside H1AA11 resistor (R18). There are two R18s, and I'll refer to them as Inside and Outside R18s. The Outside R18 is the one closest to the edge of the PCB. (I'll see if I can take a picture of my board.). By cutting this track, the H11AA1 will be floating with reference to the HOT on the TRIAC (240VAC in this example).
3. Fitting a jumper wire. With the original design, you only needed to connect the White (neutral) to the 2 pole terminal block. The terminal block is located on the right hand side of the PCB, and has a N and and a NC marked on the silkscreen overlay. using a short piece of jumper wire, solder a connection between the NC on the terminal block and the hot side of the Inside R18. This will replace the track you cut in Step 2.
3. Fit two R18s to the PCB. Now that the PCB has been modified, you need to fit two new resistors to the ZC circuit. I am going to use a 30VAC CT transformer to power my board (via a Diode rectifier circuit). Taking a tap from the transformer
Computer feed/power cable
Now you have installed all the parts, the next decision is how you will connect the controller to the PC, and how you will power the board.
The majority of the controller is run from a 5 volt DC regulator that is located on the PCB. The regulator is a 7805, and will provide a regulated 5VDC supply. The input voltage for the controller needs to be at least 9 VDC and no more than 15 VDC.
Checking the datasheet for the 7805, the minimum input voltage must be 2.0V greater than the V(out) = 7.0 V and with the input power diode (1N4001) having a Maximum Instantaneous Forward Voltage Drop of 1.1V, the absolute minimum is 8.1V.
