Revision as of 03:52, 27 July 2013 by Jklingert (talk | contribs) (Intro)
There are many different types if controllers used for RGB lighting effects. The most common fall into two different categories:
  • Pixel Controllers
  • Dumb RGB Controllers.
  • Renard (using either RS232-serial or RS485)
  • E1.31 (DMX over Ethernet)
  • DMX A traditional stage lighting protocol
  • Programs stored on SD memory cards
  • Lightorama LOR compatable gear
  • Communications Protocol (E1.31, Renard, DMX, LOR, Etc.)
  • Pixel Voltage (5VDC vs 12VDC)
  • Pixel Type (WS2801, WS2811, GECE, LOR, Etc.)
  • Number of Pixels to be Controlled
  • Number of Connectors and Number of Strings that can be Physically Connected
  • Advanced Features
    • Grouping (ability to treat multiple Pixels as one)
    • RGB Ordering (ability to correct the physical RGB order to match the software sequence order)
    • ZigZag (Ability to treat physical strings as multiple logical strings)
    • Reverse order (ability to reorder the channels on a string so the most distant one is the first channel)
    • Etc.
PIXEL CONTROLLERS
Renard PX1 Pixel Controller Under development
SanDevices
E68x Configuration Guide
Firmware Updates
Model Max Pixels DMX Universes Pixels Supported Output Connectors Max Channels DMX Universes per Output Image Link Price Manual Note
E6804-4 2040 7Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 4 Fused (1x4 Electrical, 4x1 Logical) 6120 Up to 12 link Assembled/Tested: $99, Full Kit: Price $69 Presale Owner's Assembly Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement
PS-1 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Turnkey System: $399 Owner's Assembled E682 with power supply in an Enclosure
E682-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly To be released shortly
E682-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly Original E682, Before Firmware Upgrade
E681-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link No Longer Available Owner's Assembly Firmware To be released shortly, requires UP1 upgrade
E681-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link No Longer Available Owner's Assembly Original E681, with Firmware Upgrade and UP1 upgrade
E681-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link No Longer Available Owner's Assembly Original E681, without Firmware Upgrade and without UP1 upgrade
E680-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly To be released shortly, requires UP1 upgrade
E680-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, with Firmware Upgrade and UP1 upgrade
E680-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, without Firmware Upgrade and without UP1 upgrade
Joshua 1 Systems (J1SYS)
Tutorial Video
Setup Video
Unofficial Users Manual
ECG-P12R 2040 12Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 12 Fused (2x6 Electrical, 3x4 Logical) 6120 1 link Assembled Board: $175 Owner's Notes
ECG-PIXAD8 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 8 Fused (2x4 Electrical, 2x4 Logical) 4080 1 link Assembled Board: $155 Owner's
ECG-P2 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (2x1 Electrical, 2x1 Logical) 4080 4 link Assembled Board: $68, Assembled Board w/case: $77 Owner's
Stellascapes
E16-II Green 672 6Unicast Stella-green 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1296 16 Character LCD Display for diagnostics and identification information.
E16-II Commercial 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1995 With power supply and 16 400mm "tails" with waterproof screw up connectors
E16-II Pro 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $?? With power supply and Neutrik XLR, power and ethernet chasis connectors
E2 170 1Unicast Stella-black 2 ? 512 ? link Assembled Board: $?? With power supply,operates on low voltage DC (12-48V)
DMX512 to SPI
DCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $53 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
uDCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $42, Assembled Board w/Case: $48 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
Ray Wu
(China Based)
HolidayCoro
DIYB
Electron Design
(Israel based)
AVD
ACL Wiki
ACL Thread
ACL
Onumen
RPM
Stellascapes
  • T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
  • ECG-PPX
  • ECG-PPD-A – Powered Pixel Driver - 7VDC – 12VDC input range
  • ECG-PPD-B – Powered Pixel Driver - 7VDC – 40VDC input range
  • ECG-PPD-C – 4 Channel Powered Pixel Driver - 7VDC – 40VDC input range on Channel 1
  • ECG-PPR-A – Multi-Mode Powered Pixel Receiver
  • ECG-PPI-A – Powered Pixel Injector - 7VDC-40VDC Input, 5VDC 1.5A output
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
Discussion Thread
USB to DMX512 Output
FTDI drivers for dongles:
DC Controller Comparison Table
Audiolight Intl HD-714 [1] [2] Yes 12V - 24V 3 2A 6A DMX $8.95 $2.98
Audiolight Intl HD-712 [3] [4] Yes 12V - 24V 27 1A 15A DMX $44.21 $1.64
Leynew LN-DMXMODEL-3CH-LV12 [5] [6] Yes 12V 3 2A 6A DMX $7.49 $2.49
Different Styles of Pixels
