Assembly Instructions The Renard SS16
Board Assembly
- The following sequence of steps is by no means the only way to assemble the Renard SS16. It is simply a suggested order of events to achieve the desired goal.
- NOTE: The part numbers referenced in the following instructions are those taken from the Renard SS16 BOM.
Triac Heat Sink
- A simple heat sink can be fabricated from .5"x.5"x.060" (1/16”) angle aluminum available at your local home improvement store. You can use a larger size angle if desired, but you have to keep with the 1/16" thickness A template for the hole pattern can be found here. The triac listed in the BOM has an isolated tab, so no isolators are needed.
- Another method for making a heat sink is to use flat aluminum (1/16” thick) instead of angled. The heat sinks most commonly included in group buys are made in this fashion. The hole pattern is the same as above and the overall dmensions are shown here.
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
QTY | REF | NOMENCLATURE |
| 815-ACH-18.432-EK | 1 | U3 | Crystal Clock Oscillator, 18.432 MHz |
| 579-PIC16F688-I/P | 2 | U6, U7 | PIC Microcontroller |
| 571-1-390261-3 | 2 | IC Socket, 14 pin (for U6, U7) | |
| 859-MOC3023 | 16 | M1-M16 | Optoisolator, Triac Driver |
| 571-1-390261-1 | 17 | IC Socket, 6 pin (for U2, M1-M16) | |
| 511-BTA06-600CW | 16 | T1-T16 | Triac, 6A 600V |
| 299-680-RC | 17 | R6, R10-R25 | Resistor, Carbon Film 680 ohms 1/8W 5% |
| 291-180-RC | 16 | R26 – R41 | Resistor, Carbon Film 180 ohms 1/4W 5% |
| 511-1N5817 | 4 | D1-D4 | Diode |
| 604-WP710A10IT | 2 | FE, OE | LED, 3mm Red |
| 604-WP710A10GT | 4 | PWR, HB, ZC, SD | LED, 3mm Green |
| 140-REA222M1CBK1320P | 1 | C1 | Radial Electrolytic Capacitor 16V 2200uF 20% |
| 140-REA470M1CBK0511P | 1 | C2 | Radial Electrolytic Capacitor 16V 47uF 20% |
| 80-C322C104K5R | 2 | C3, C4 | Capacitor, Radial Ceramic 50V 0.1uF |
| 571-2828372 | 16 | Channel Terminals | Terminal Block, 2 Pos 5.08 mm |
| 571-7969492 | 2 | Power Terminals | Terminal Block, 2 Pos 5.08 mm |
| 737-MSB-G | 3 | Shunt | |
| 504-GMA-10 | 2 | F1, F2 | Fuse, Fast Acting 10A |
| 534-3517 | 4 | Holder, Fuse Clip PCB mount 5mm | |
| 534-3527C | 2 | Cover, Fuse | |
Hardcopy Instructions
