E1.31 (Streaming-ACN) Protocol
THIS WIKI PAGE IS NOT COMPLETE YET AND HAS NOT BEEN CHECKED FOR ERRORS.  IT IS A WORK I PROGRESS.  :)
Protocol Description
The simplest way to think about E1.31 is that it is a way to transport a large number of lighting control channels over a traditional ethernet network connection. E1.31 transports those channels in "Universes", which is a collection of 512 channels together. E.131 is ethernet based and is the data sent via UDP. The two accepted transport methods are multicast and unicast, the most common implementation is multicast. When using multicast all the controller needs to do is subscribe to the multicast address for the universe that you want to receive data from.
Unicast vs. Multicast
Unicast
Unicast is a method of sending data across a network where two devices, the control PC and the lighting controller, are directly connected (or thru a network switch or router) and the channel control information meant for that specific controller is only sent to that controller.  Unicast is a point to point protocol and only the lighting channel information is only switched or routed to the device with the matching IP address.   In this case, the same IP address (commonly 192.168.1.206) that is used to access the web configuration page is the same address the the lighting control information is sent to.  You must have unique IP address in each controller.  Using Unicast the data packets are sent directly to the device instead of being broadcast across the entire subnet.
Multicast
Multicast  is a method to send data across a network where a sender, typically a PC, broadcasts the data to all devices connected to the network subnet  and the information about the channels are sent to all controllers connected to the network and every other device on the network.  Multicast is a point to multipoint broadcast where the controllers need to listen to and only respond to information they are configured to use.  Your PC sequencing software or streaming tool sends multicast packets with an address of 239.255.<UHB>.<ULB> where UHB is the Universe high byte and LHB is the Universe low byte. As an example, the address for universe '1' would be 239.255.0.1. This is why using multicast addressing can be simpler to configure since this address is always the same for any device using that universe. The disadvantage of using multicast is that the packets are sent to every device on the subnet regardless if they are destined for it or not. This means the receiving device must read in the header for each packet or have the means to block these within hardware. Depending on the device and the number of universes of data sent it can swamp the device and possibly end up causing a loss of data. Note however that this is not an issue for most networks until you get into the dozens of universes so it's not an issue for most users.  With Multicast you must also have a unique IP address for each controller so that you can access its webpage that allows configuration.  The data is received on multicast IP address not on the configuration IP address.
Advantages of Unicast vs. Multicast
- Unicast
 - Less data on home network due to routers and switches sending data only to selected devices and not all devices on network
 - Multicast
 - Busier home network due to teh fact that Multicast sends information to every device on the homenetwork and they need to deal with it (not just controllers, but other PCs, TV, game consoles, etc)
E1.31 Network Layout
E1.31 Pixel Controllers
In one common use, the light control software on the PC sends the lighting sequence data out to the controllers that are connected to the pc thru ordinary ethernet connections such as a router or switch. The controllers listen for the data addressed to them and then control the lights that are connected to it.
E1.31 Bridges
Another common usage of E1.31 is an E1.31 Bridge.
Configuring Sequencing Software to use E1.31 Output
In order for your light sequencing sotware to communicate via E1.31 protocol, the software needs to have the output configuration setup done in the software. This varies from software package to software package.
Using E1.31 with Vixen
Using E1.31 with LOR S3
Using E1.31 with HLS
Using E.131 with xlights (Nutcracker)
Download xlights here Nutcracker Remeber that E682 lighting controllers only use 510 channels, no the full 512 channels per universe when you setup our controllers
These tools allow you to test E1.31 controllers simply without using sequencing software. They are good tools to use when troubleshooting a E.131 network setup.
