Pixel/RGB Wiring Colors
Pixels generally have 3-4 wires connected to each pixel:
- +5 or +12VDC Power Feed
- Ground Power Feed
- Data/ Signal
- Clock (not on all pixels)
Because pixels are sending control signals down the wires, there is an input set of wires and an output set of wires coming from each pixel.  You can generally find markings such as words or arrows that identify the data direction for each set of wires by looking closely at the printed circuit board inside of the pixel.  Other clues may include individual pin markings such as "SDO" Serial Data Output, "SDI" Serial Data Input, "CKO" Clock Output or "CKI" Clock Input.  it is common to have the power on the two outer wires on a pixel and the data and clock as the inside wires.  Many strings come two ground wires connected to the input and output sides.
Unfortunately there is no standard wiring color code for pixels supplied by different manufacturers.
DIYLEDEXPRESS.COM Pixels
WS2811 Pixabulbs
WS2811 Pixelabulb Strings (Input is end of string with male connector)
| Ground
Data
+12V
| Black
Green
Red
PICTURE TBD
WS2811
WS2811 Pixel Strings (input is not chip side)
| Ground
Data
+5V
| Blue (GND)
White (DI)
Red (+5v)
PICTURE TBD
WS2801
WS2801 Pixel Strings (input is chip side)
| Ground
Clock
Data
+5V
Output Side Photo
| Blue (GND)
Green (CKO)
White (SDO)
Red (+5v)
TM1809
TM1809 Pixel Strip
| +12V
Ground
Data
| Red (+)
Blue (-)
Green (DI/DO)
Other Vendors
Thanks to http://www.auschristmaslighting.com for this great info.
WS2801
WS2801 Pixel Strings (input is non-chip side usually)
| Scheme
+5V
0V
Clock
Data
| 1
Red
Blue
White
Black
| 2
Red
White
Green
Blue
| 3
Red
Blue
Green
Yellow
| 4
Red
Yellow
Blue
Green
| 5
Black
White
Red
Blue
Sources:
- Fasteddy
- Blickensderfer
- ThaiWay
- Stella Black
- JPB
TM1804
TM1804 Pixel Module (Square)
| Signal
Wire Colour
Marking
| +12V
Red
+12V
| Data
Green
DI
| 0V
Blue
GND
TM1804 Pixel Module (Rectangular)
| Signal
Wire Colour
Marking
| +12V
Red
| Data
Green
DI
| 0V
Blue
TM1804 Pixel Strings (Input is on chip side)
| Signal
Wire Colour
| +12V
Red
| 0V
Green
| Data
Blue
LPD6803
LPD6803 Pixel Strip
| Signal
Wire Colour
Marking
| +12V
Red
Di
| Data
Green
Ci
| Clock
Blue
St
| 0V
White
Li
LPD6803 Pixel String (RGB order)
| Signal
Wire Colour
| +5V
Red
| 0V
Yellow
| Data
Green
| Clock
Blue
LPD6803 Pixel String (GRB order)
| Signal
Wire Colour
| +5V
Red
| Data
Green
| Clock
Blue
| 0V
White
| Signal
Wire Colour
| 0V
Blue
| Clock
Red
| Data
Green
| +24V
Black
P9813
P9813 Pixel String (BGR order) Input is on chip side
| Signal
Wire Colour
| +5V
Red
| Data
Green
| Clock
Blue
| 0V
White
DC (No IC)
DC RGB Pixel String
| Signal
Wire Colour
| Blue
Blue
| Green
Green
| +5
White
| Red
Red
DC RGB Module (input Left Hand Side)
| Signal
Wire Colour
| +12
Yellow
| Green
Green
| Red
Red
| Blue
Blue
GECE Wiring
http://sandevices.com/documents/GE_Pixel_Wiring.pdf
Different Styles of Pixels
