Generally pixels come from vendors without connectors attached or they have proprietary non waterproof connectors connected to them.  Most people utilize some form of water resistant connectors attached to their pixels and the mating connector to their pixel controllers.  It is common to install the female connector (socket end) to the power source (controller) and the male connector( plug end) to the pixel string.  Some people also use dielectric grease or protective spray like CorrosionX to further prevent corrsion and oxidation of the electrical contacts due to moisture.  The number of conductors required for each pixel type depends on the number of wires that pixel requires.  Some pixels only need 3 wires, Ground, V+ and Data while some require a fourth Clock wire.
Connectors from different vendors generally do not fit together due to different manufacturers sizes and keying.
| Pixel Connector Properties | ||
| Feature | ||
| Options | ||
| Type | Euro, Cap, Pigtail, Tee, Extension | |
| Color | White, Black, Clear | |
| Conductors | 2,3,4,5 wires or pins | |
| Length | Varies per vendor | |
| Diameter | 13.5mm, 15mm, other | |
| Wire Size | typically 18-22ga | |
Types of Pixel Connectors
Euro Connector
These connectors are typically found on pixel controllers like the Sandevices E682 of the Renard PX1. They are polarized and the plug only fits in the socket one way.
Euro Female socket
The female socket is typically soldered to the controller PCB.  They can be purchased from various vendors like Mouser
Because the plug and socket are polarized it is critical that you connect the wires correctly to the controller and the pixels.  The wire order for the typical E682 pixel controller is:
| E682 Pixel Output Pin Assignments | ||
| Pin # | ||
| Signal | ||
| 1 | GND (V-) | |
| 2 | Clock (C) | |
| 3 | Data (D) | |
| 4 | V+ | |
Euro Male Plug
The male plug is generally attached directly to the pixels or may be connected to a pigtail.  They can also be purchased from Mouser in two versions:
one with an inline wire entry like used on the Sandevices E682
and one with a rear wire entry as used on the Renard PX1
Pigtails
These are typically connected to the end of the pixel strings and to controllers to allow an easy way to quickly connect and disconnect the pixels using a "waterproof" connector. They are generally sold as a pair of male and female ends. Pigtails are polarized so that they only fit together one way. They can have either a notch and tab or a flat spot on the male end that must interlock with the corresponding feature on the female end. The wires on pigtails are color coded, but may vary from batch from the same vendor. It is wise to confirm which pin on your pigtails are connected to which color wire before you solder them and test fit to make sure they properly function. The wire color code for the pixels also can vary from batch to batch. Here is an example of some pixel wire color codes. Check with your vendor to make sure you have the right color code and the correct input side for your specific pixels.
Male Pigtail
Male Pigtails are generally connected to the input end of a pixel string. Male pigtails often have a separate o-ring that must be slid on to the body into the notch. There is also a locking nut that slides down over the back of the male pigtail and is used to tighten the male plug into the female socket.
Female Pigtail
Female pigtails are generally connected to the device supplying the power. It is common to use a female pigtail connected to a Male Euro connector to a E682 style pixel controller. The Euro connector connects to the pixel controller and the female pigtail extends the cord outside of the enclosure that the controller is mounted in. It is also common to connect a female pigtail to the end of a pixel string to connect to the next pixel string in series.While there is no official standard color code for the pigtails, Sandevices and Ray Wu are using this for their connectorized pixels:
| Pixel System 1 Female Pigtail  | ||
| Wire Color | ||
| Signal | ||
| Black | Ground | |
| Blue | Clock | |
| Green | Data | |
| Red | V+ | |
Tee
Often used for power injection. Depending on the vendor, they may have all wires connected thru to all three jacks, or some may have only some wires connected.
Extension cable
Caps
These typically go on unused female pigtail ends to seal them from the weather.
Wire Sizing
It is desirable to use the largest wire diameter (smaller wire gauge) that you can when connecting your pixels to your controller.  The smaller wire gauge results in a high voltage drop and can cause your pixels to have poor colors or to not function at all. For more information about how to choose the right wire size look here.  This is also a good thread that discusses voltage drop.
This is a Voltage Drop Calculator useful for calculating the effects of different wire sizes and lengths on pixel strings.
| Wire Sizing | ||
| Wire Gauge (AWG) # | ||
| Cross section Area (mm2) | ||
| 14 | 2.08 | |
| 16 | 1.31 | |
| 18 | 0.823 | |
| 20 | 0.518 | |
| 22 | 0.328 | |
These are selected connectors from the various vendors with a mix of properties. Visit their sites for the latest information and to see their entire product catalog. Many of the vendors can provide custom length wires and custom quantity pricing on the pigtails and extension cables.
DIYLEDEXPRESS
| Type | Color | Conductors | Length | Diameter | Link | Image | Quantity | Price | Price per Connector | Note |
| 2 Conductor | ||||||||||
| Pigtail | White | 2 | 10" | link | 10 | $11.85 | $1.190 | 18 ga wire | ||
| 3 Conductor | ||||||||||
| Pigtail | Green | 3 | 10" | link | 10 | $12.50 | $1.25 | 18 ga wire, fits Pixabulbs | ||
| Extension | Green | 3 | 5feet | link | 1 | $2.25 | $2.25 | fits Pixabulbs | ||
| Extension | Green | 3 | 10feet | link | 1 | $3.50 | $3.50 | fits Pixabulbs | ||
| Tee | Green | 3 | link | 1 | $3.79 | $3.79 | fits Pixabulbs | |||
| 4 Conductor | ||||||||||
| Pigtail | White | 4 | 10" | link | 10 | $12.00 | $1.20 | 18ga wire | ||
| Extension | White | 4 | 5feet | link | 1 | $2.25 | $2.25 | |||
| Extension | White | 4 | 10feet | link | 1 | $3.75 | $3.75 | |||
| Tee | Green | 4 | link | 1 | $4.50 | $4.50 | fits Pixadot strings |
HolidayCoro
| Pigtail | White | 4 | 15" | link | 1 | $2.19 | $2.19 | 20ga wire | ||
| Pigtail | White | 4 | 34" | link | 1 | $2.49 | $2.49 | 20ga wire | ||
| Extension | White | 4 | 9'10" | link | 1 | $4.09 | $4.09 | 20ga wire | ||
| Tee | White | 4 | link | 1 | $3.99 | $3.99 | 20ga wire |
Ray Wu
(China Based) Contact Ray Wu directly for lower shipping costs if you are ordering multiple items.
| Cap | White | 13.5mm | link | 10 | $0.50 | $0.05 | End cap to go on unused male plugs | |||
| Cap | Black | 13.5mm | link | 10 | $0.50 | $0.05 | End cap to go on unused male plugs | |||
| Pigtail | White | 2 | 20cm | 13.5mm | link | 10 | $3.00 | $0.30 | 2x0.5mm²wire | |
| Pigtail | Black | 2 | 15cm | link | 50 | $23.16 | $0.46 | |||
| Pigtail | Clear | 2 | 10cm | link | 100 | $57.89 | $0.58 | Coaxial 5.5/2.1mm 22gauge wire | ||
| Extension | White | 2 | 1.5m(5feet) | link | 10 | $10.00 | $1.00 | 2x0.5mm² wire | ||
| Extension | White | 2 | 3m(10feet) | link | 10 | $16.00 | $1.60 | 2x0.5mm² wire | ||
| Tee | White | 2 | 40cm | 13.5mm | link | 10 | $17.00 | $1.70 | 2x0.5mm² wire | |
| Tee | Black | 2 | 40cm | 15mm | link | 1 | $2.20 | $2.20 | 2x0.75mm² wire | |
| Pigtail | White | 3 | 20cm | 13.5mm | link | 10 | $5.00 | $0.50 | 3x0.5mm²wire | |
| Pigtail | Black | 3 | 20cm | 13.5mm | link | 10 | $5.00 | $0.50 | 3x0.75mm² wire | |
| Pigtail | White | 3 | 30cm | 13.5mm | link | 10 | $6.00 | $0.60 | 3x0.5mm² wire | |
| Pigtail | Black | 3 | 20cm | 15mm | link | 10 | $5.00 | $0.50 | 3x0.5mm² wire | |
| Extension | White | 3 | 1.5m(5feet) | link | 10 | $12.00 | $1.20 | 3x0.5mm² wire | ||
| Extension | White | 3 | 3m(10feet) | link | 10 | $18.00 | $1.60 | |||
| Extension | White | 3 | 7.6m(25feet) | link | 10 | $37.00 | $3.70 | |||
| Extension | Black | 3 | 1.5m(5feet) | 15mm | link | 10 | $12.00 | $1.20 | 3x0.5mm² wire | |
| Extension | Black | 3 | 3m(10feet) | 15mm | link | 10 | $22.00 | $2.20 | ||
| Tee | Black | 3 | 40cm | 13.5mm | link | 10 | $19.00 | $1.90 | 3x0.75mm² wire | |
| Tee | White | 3 | 40cm | 13.5mm | link | 10 | $18.00 | $1.80 | 3x0.5mm² wire | |
| Pigtail | White | 4 | 30cm | link | 10 | $8.00 | $0.80 | |||
| Pigtail | Black | 4 | 20cm | 13.5mm | link | 10 | $7.00 | $0.70 | 4x0.75mm² wire | |
| Pigtail | White | 4 | 150cm(5ft) | link | 10 | $19.00 | $1.90 | |||
| Pigtail | Black | 4 | 20cm | 15mm | link | 10 | $7.00 | $0.70 | 4x0.5mm² wire | |
| Extension | White | 4 | 1.5m(5feet) | link | 10 | $12.00 | $1.20 | |||
| Extension | White | 4 | 3m(10feet) | link | 10 | $19.00 | $1.90 | |||
| Extension | White | 4 | 7.6m(25feet) | link | 10 | $39.00 | $3.90 | |||
| Extension | Black | 4 | 2.5m | 15mm | link | 10 | $22.00 | $2.20 | 4x0.75mm² wire | |
| Extension | Black | 4 | 7.6m(25feet) | 15mm | link | 10 | $44.00 | $4.40 | 4x0.75mm² wire | |
| Tee | Black | 4 | 40cm | 13.5mm | link | 10 | $22.00 | $2.20 | 4x0.75mm² wire | |
| Tee | White | 4 | 40cm | 13.5mm | link | 10 | $22.00 | $2.20 | 4x0.5mm² wire | |
| Tee | Black | 4 | 40cm | 15mm | link | 10 | $24.00 | $2.40 | 4x0.5mm² wire | |
| 5 Conductor | ||||||||||
| Pigtail | White | 5 | 15cm | link | 100 | $96.84 | $0.97 | |||
| Pigtail | Black | 5 | 20cm | 15mm | link | 10 | $8.50 | $0.85 | 4x0.5mm² wire |
Seasonal Entertainment
| Pigtail | White/Black | 4 | 6.5" | link | 1 | $4.00 | $4.00 | |||
| Extension | White/Black | 4 | 1m | link | 1 | $7.15 | $7.15 | |||
| Extension | White/Black | 4 | 3m | link | 1 | $10.30 | $10.30 |
Different Styles of Pixels
