When your working with pixels or any type of led, they will be ran on DC voltage. To do that you will need to run some sort of power supply. There are many types you can use.
Power Supply Voltages
With 5v the voltage drop will be noticeable if your trying to push the voltage for a long run. Most likely you will need to inject the power again or feed from the center of the pixel string. For every 50 pixels, you should re-inject the power. So a good example, if you have a 100ct pixels string you can connect the signal wires end to end, but you will either have to put the power at the center of the string to feed each side. Or you will have to put a power source on either end. A 50ct pixel string will pull around 3amp (50x.06=3amp). So really finding smaller power supplies is a good thing to have if you have your pixels spread around the yard. If you have like a pixel megatree then you can do a large power supply to feed the whole tree. So bigger is not always better esp if your not power alot of pixels close by.
12 volt is a bit different. You can push 12v further than 5v. So that does have its advantages and disadvantages. Most pixels strings are only 5v. There are some that are starting to 12v but it may be a bit before more start to come out. So 12v is alot nicer but not as many options.
Waterproof Power Supplies
| 5VDC | ||||||||||
| 12VDC | ||||||||||
| Holiday Coro | 45W Waterproof Switching Mode | 100-130 VAC | 12VDC | 3.75A | link | $12.39 | $3.30 | 1"x1.2"x9.7" | IP67 | |
| 24VDC | ||||||||||
Power Supply Connections
The power supplies generally have screw terminals to connect power wires to.
| Typical Power Supply Terminals | ||
| Label | ||
| Connection | ||
| L - Line | Connects to the Hot side of 115VAC power cord(Black wire) | |
| N - Neutral | Connects to the Neutral side of 115VAC power cord (White wire) | |
| Gnd - Ground | Connects to the Ground wire of 115VAC power cord (Green wire) | |
| V+ | Positive voltage output to Controllers | |
| V- | Negative voltage output to Controllers | |
| 5VDC | ||||||||||
| Holiday Coro | 350W Switching Mode | 100-130 VAC | 5VDC | 60A | link | $32.95 | $0.55 | 2"x4.5"x8.5" | Fan Cooled | |
| 12VDC | ||||||||||
| Holiday Coro | 350W Switching Mode | 100-130 VAC | 12VDC | 29A | link | $29.95 | $1.03 | 2"x4.5"x8.5" | Fan Cooled | |
| 24VDC | ||||||||||
Converting ATX Power Supply
One common low cost way to generate +5VDC and +12VDC is to convert an old used PC power supply that you have salvaged from an unused PC. There are numerous plans available on the internet showing you how to convert them.For more information see:
Wall Warts
Wall warts are not the greatest to try to run pixels off of. First off most are too small to supply enough amperage. Also they do not supply very clean power to the pixels. Your best bet is to stay way from these.
Due to the very high current that many power supplies are capable of putting out (>60A) it is a good idea to use a heavy guage wire fuse holder between the power supply and the controller hookup. The large gauge wire will minimize any voltage drop that may occur in the wire due to high current. It is common to use 12-14ga wire to connect power supplies with pixel controllers. Mouser.com carries several inline fuseholder that take automotive style fuses such as part number 441-R347A-GR that has 12 ga wire and can use up to 30A ATC style fuse, or part number 441-R347B-GR that has 14ga wire and can use up to a 20A ATC style fuse.
