Renard PX1 Pixel Controller
General
Features
- Standard Renard connections
- 5VDC and 12VDC operation
- WS2801 and WS2811 pixels
- Some Design Details:
- One output (same 3.5mm connector and pinout as jstjohnz's controller), handling up to 200 pixels
- RS485 input, same RJ45 pinout and protocol as Renard controllers
- 115200 input baudrate (lower rates provided, but not recommended)
- Uses PIC16 parts, so existing programmers should work.
- Supports WS2811 strings at with either 400KHz or 800 KHz data rate, 5V or 12V power input
- Uses external 5V supply (readily available from Ebay, China, etc).
- Power, RxD and FE (framing error) indicators
| 100 ms | 50 ms | 25 ms | |
| 230400* | 764 | 382 | 191 |
| 115200 | 382 | 191 | 95 |
| 57600 | 191 | 95 | 47 |
| 38400 | 127 | 63 | 31 |
| 19200 | 63 | 31 | 15 |
PCB Layout
BOM - Bill Of Materials
| R6 | 264-680-RC | Resistor Network, 680 Ohm, Bussed, 6-pin | 1 | |
| C1 | 810-FK28X5R1C105K | Multilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10% | 1 | |
| J4 | 649-77313-122-10LF | Headers & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH | 1 | |
| J9 | 571-2828372 | Fixed Terminal Blocks 5.08MM PCB MOUNT 2P | 1 | |
Assembly Instructions
- Configure Jumpers
- Program PIC
- □ Install Resistors
- □ R4 - 680 ohm bussed resistor. Note that this resistor is polarized and only can go in one way. The dot on the package denotes pin1.
- □ Install Capacitors
- □ Install Diodes
- □ Instal IC Sockets
The notch faces right.
The Notch faces right.
- □ Install LEDs
- □ D3,D4 - Red LED. LEDs are polarized and they have to be installed with the correct orientation. The anode side of the LED with the longer leg goes in the top round hole.
- □ Install Voltage Regulator
- □ IC3 - LP2950CZ-5.0/NOPB voltage regulator. The voltage regulator is polarized and it has to be installed with the correct orientation. Install in location U3 with the flatside of the regulator facing the top of the board and mmatching the orientation on the silkscreen.
- □ Install Fuse Holder
- □ Fuse holder.
- □ Install Connectors
- □ J8 - 2 pin screw terminal. Install so the wire opening faces off the edge of the board.
- □ J9 - 4 pin euro style header.
- □ Install RJ45 Jacks
- □ J5,J6 - RJ45 Jack. The jacks are polarized and they have to be installed with the correct orientation.
- □ Install Fuse
- □ Install 5A fuse.
- □ Install ICs
- □ IC1 - SN65LBC179PE4, RS485 line chip. The IC is polarized and it has to be installed with the correct orientation. The IC has a notch on one end and the notch must be installed to match the direction on the silkscreen.
- □ IC2 - PIC16F1825-I/P PIC microprocessor. The IC is polarized and it has to be installed with the correct orientation. The IC has a notch on one end and the notch must be installed to match the direction on the silkscreen.
Configure Jumpers
J3- DMX Termination Resistor
Install a jumper across these two pins only if you are using DMX input. For Renard input, leave the jumper off.
J4- 2x5 Options Connector
J5- RS232
Install a jumper across these two pins only if the input is RS232 from a PC or Dongle directly. For RS485, or from the output of another Renard controller, leave this jumper off.
J7- Programing?
J8- 5VDC Regulator Bypass
This 3 pin jumper is used to select the power source of the control circuit on the board. If the power input to the board is 12VDC, then jumper must be placed on the two left pins. If the power input to the board is 5VDC, then the jumper must be placed on the right two pins.
Program PIC
Connections
J1 and J2-Renard Input and Output
The two RJ45 Connectors J1&J2 near the top of the board are used to bring data signals to and from the board. J1 on the left side is the signal input from the PC or previous Renard controller. J2 on the right side is the output to be daisy-chained to the next Renard controller. The pins on these connectors are used as follows:
| Pin # | RJ45 Connector | |
| J1 Input | J2 Output | |
| 1,2 | GND | GND |
| 3 | NC | NC |
| 5* | Data+ (Rx) | Data+ (Tx) |
| 6,7,8 | NC | NC |
*This pin is connected to GND through J5 if a shunt is installed in J5.
J6-ICSP Programming Header
J6 is the 6 pin header located in the top center of the board. J6 allows the PIC microprocessor to be programmed in place on the board by directly connecting a PICKIT2 or PICKIT3 programer.
Pin 1 is the square hole towards the left side of the board closest to D1.
| J6 ICSP Pin Assignments | ||
| Pin # | ||
| Signal | ||
| 1 | VPP/MCLR | |
| 2 | VDD Target | |
| 3 | VSS (Ground) | |
| 4 | ICSPDAT/PGD | |
| 5 | ICSPCLK/PGC | |
| 6 | N/C | |
J9-Power
J9 is the 2 pin terminal block located at the bottom left side of the PCB. The Renard PX1 can be powered by either 5 or 12VDC (depending on pixel type). If you are using 5VDC, you can omit the voltage regulator and set Jumper J8 to the bypass position.If you are using 12VDC, then you must use the on board voltage regulator.
| J9 Power Input | ||
| Pin # | ||
| Voltage | ||
| 1 (square pad on left) | GND | |
J10(4 pin)- Output to Pixels
J10 is located along the bottom right side of the board and is a 4 pin Euro style plugable connector used to connect to the Pixels. Pin1 of the connector is on the left side and is marked by the square hole on the silkscreen.
| J10 Pixel Output Pin Assignments | ||
| Pin # | ||
| Signal | ||
| 1 | GND | |
| 2 | Clock | |
| 3 | Data | |
| 4 | V+ | |
Indicator LEDs
Attn
Rx
FE
Pwr
Enclosure
