Electronics Hardware
Links
SSR Direct Attach
If you need 12 or fewer channels, you can just buy or build SSRs and connect them to the parallel port on your PC, and use them to turn 110VAC light strings (or just plain lamps) on and off (no dimming). From time to time there are coop buys of SSR boards and/or parts, so reduce your expense.
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: GRINCH Controller Assembly Instructions
 - Documentation: Olsen 595
Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS485, so a USB-RS485 (or RS232-RS485) converters are required. This system is available on a coop basis from time to time, with the kits including the boards, the parts, and pre-programmed microcontroller chips (PICs). This board is intermediate in complexity to build.
Renard
 - Documentation: Renard
Lynx
- Controlled through: DMX
Ledtriks
JEC Pixel Displays
TBA
rgbLED
TBA
			SSR (solid state relay)
			595 Coop Board
			Grinch
			Renard (by FKostyun: 24 ports with on-board power supply and SSRs)
			Lynx (DMX dimmer)
			Inside the Lynx
			Ren16 (xmus)
