Results 1 to 8 of 8
Thread: 12 volt pixel issue
    Jan 2021
    3
    Default 12 volt pixel issue
    I am hoping someone has seen this problem before. I bought some new strings of 12 volt WS2811 100 node pixels. 5 strings, so 500 pixels. My problem is when I hook them up to my F16V3 falcon controller, the first 8 pixels come on by them selves. When I run a sequence all the other lights(92) work as they should. All 5 strings do this. I have never seen this, hoping that someone on here has.
    5,077
    Default Re: 12 volt pixel issue
    please post a picture of the port/string configuration page. Also put the f16 into test mode and tell us if you still see the issue.
    Jan 2021
    3
    I have put it in test mode, and the first 8 dont respond. The first 7 stay blue and the 8th one is green. i am posting pictures not in test mode and in test mode. I have another ws2811 50 pixel string hooked up and it works fine.20210619_193615.jpg20210619_193600.jpg20210619_193600.jpg20210619_193622.jpg20210619_193622.jpg20210619_193622.jpg20210619_193622.jpg20210619_193616.jpg20210619_193615.jpg20210619_193615.jpg
    5,077
    if string 2 works then the config is ok. i would start removing one pixel at a time until you have a (shortened) string that works.
    1,885
    It is odd that all your strings have the same problem. Did you use the same pigtail on all the tests?
    Did you try attaching the strings to the end of the good string?
    5,077
    This statement "I have another ws2811 50 pixel string hooked up and it works fine" indicates the issue is with the pixel string that is not working. However, is this "other" string hooked up to the same port that is having an issue? Making such a statement about a string on a different port is not useful and can be misleading. If you say that you have a string that works fine on port X and when you move it to port Y it stops working properly, that is a big piece of data. Have you tried the non working string on a known working port? Have you tried a known working string on the port that is having issues? This is data that is needed to debug such an issue. That or start cutting up your string and if the issue ove up the string then you know you have a problem port and if the working pixels continue to work then you know you have bad pixels. I would swap strings between ports first.
    Martin
    Jan 2021
    3
    Thanks for all the replies, I took all your advice. I swapped ports, pigtails and tried all lights hooked together. I narrowed it down to the last 8 ports on the control board. After doing a reset and inputting all my configurations again, it solved the problem. I'm really not sure what caused it, but I'm glad it works now. Thank you again
    Colorado Springs
    3,896
    More than likely you had overlapping channels............
