Wrong colors in FPP
TomsLEDs
Supporting Member
I have a large megatree that requires 2 contoller boxes. When a sequence is played direct from Vixen or a test pattern on the cards, the colors are correct. When a sequence plays in FPP, only that tree is off color. The current mapp is uploaded from Vixen `along with the sequence but the color is still wrong. I ended up changing the RGB order on each controller so the color was corrected. I know the color test in Falcon is not reliable, but in this case when I matched it and ran a sequence it worked. Am I missing something?
Thank you sir. I glanced at it last night but nothing was obvious. I will map it out tonight and see what I find.
That should be it. The DMX controller for the Pi was set to 255 outputs in Vixen, but 100 outputs in FPP. The megatree controllers were added after that last address.
Raining right now, I will fix it tomorrow.
Back
Top
