Mudsculpter
Supporting Member
Would a left over cellphone charger cord work for supplying the necessary 5v power?
If so, what is the maximum voltage that can be run through a fully populated 595 board (w/LEDs) without ruining it.
Should I be concerned with the amp rating of the 5v charger?
If a higher than 5v charger can be used, what volt/amp combo is desirable?
And while i'm asking questions,...What is the migratory pattern of a coconut-laden swallow if said bird grips the husk slightly askew?
