Hi there - I've been running my lights with a Raspberry Pi 3 Model B+ for quite a few years with no real issues, along with very solid 'if it ain't broke don't fix it' FPP v2.4 (it could be 2.3, I don't have a screenshot of the home page). I use all 4 USB outlets - two are connected via Renard Protocol to 176 channels (6 ss24s and 1 Ren32); a third USB port is used for a DMX controller for some RGB flood lights; a fourth USB port connects to an external sound card to clean up my audio a bit. I connect the ethernet port to an ethernet switch, that's also connected to a couple sandevices e682s, and a wifi access point. The Pi has a wifi config and a lan config, and I usually communicate with it through the wifi (because that side is connected to the rest of my home network). I can also communicate with it through the LAN side, either ethernet connection into the switch or connecting to the wireless AP. With some recent heavy rains, I've had everything powered down the last two days, but when I powered things up this morning, I wasn't able to access the FPP/Pi. I eventually pulled it inside to have a look thinking maybe something got wet - I can see that when I power it up it connects to wifi, and I can also see it's LAN ethernet address replying to pings on the LAN side, but when I navigate to the home screen (from either wireless or LAN side) I get a generic 'couldn't connect to the server' notice - the same i would get if I tried to navigate to a website and had no internet access. Interestingly enough, since I'm not able to navigate to the FPP homescreen, I haven't been able to reset the time - and when powered and connected it is clearly running the show from the scheduler - it's driving two pixels trees correctly, and also broadcasting audio from the player. So - everything seems to be working except my ability to navigate to the FPP homescreen. That won't really work for me because I can't adjust the date/time... and I also have some odds and ends to clean up such as resetting output port assignments for the renards because those output ports must've gotten juggled around during the powerup/powerdown testing I was doing. Any ideas about how I might be able to find access back to the FPP home screen? I've not experienced this before. The FPP version as I said is pretty old, it's not done any auto updates since I keep the show on it's on standalone network, without an internet connection. I just ordered a new Raspberry Pi today (and stuck with the same model to enable a simple replacement), but not 100% certain I'll be able to simply plug in the microSD and go... but also not 100% giving up on this one since it seems to be working. Thanks for any advice!
