Falcon F16v5 wiring schema for high-current 12V WS2815 installation — sanity check requested
Meuretti
New member
Building a 28-panel WS2815 LED screen (8×32 pixels per panel = 7,168 pixels total, 4 rows × 7 columns) for an art installation. Controller is Falcon F16v5, using 7 outputs (one per column). Each column = 4 panels in serial data chain via JST connectors. 7-day continuous run, exhibition hours 10:00–20:00, Swiss Art Awards Basel, 16–21 June 2026.
Power architecture:
  • 4× Meanwell UHP-500 (12V, 500W each) — one PSU per row of 7 panels
  • ~143A total at 100% white (verified: 0.24W/LED × 256 LEDs/panel × 28 panels = 1720W)
  • ~36A per PSU, ~5.1A per panel
  • Each PSU has 2× V+ and 2× V- terminals — splitting each row into two strings (4+3 panels) → ~20.5A and ~15.4A per terminal
  • Power and data physically separated: V+ and GND go directly from each PSU to its panels, NOT through the Falcon
Per-row distribution (no daisy-chaining):
  • Each PSU feeds two local busbars (V+ and V-)
  • 7 individual dedicated wires from each busbar to each panel's V+ / GND
  • All 4 V- busbars connected via a vertical GND backbone → common ground
Falcon F16v5 connections:
  • External Power Input: +12V and GND from common ground (controller logic only)
  • V1 and V2: GND only — no +12V (per-output E-fuse rated 5A, insufficient for ~36A/row)
  • Output V-pins: unused
  • Output G-pins: unused (GND runs externally via PSU)
  • Output D-pins: connected to first pixel's DI and BI bridged together (full backup-data redundancy from pixel #1 onwards)
Inter-panel JST connectors carry only data (DI + BI), no V/GND.
Wire gauges (DC, runs <2m, real-world average 20–40%, 100% peaks rare and brief):
  • PSU terminal → 4-panel string: 2.5 mm² (max 20.5A, real ~8A)
  • PSU terminal → 3-panel string: 1.5–2.5 mm² (max 15.4A, real ~6A)
  • Busbar → individual panel: 1.5 mm² (5.1A)
  • PSU V- → common GND backbone: 2× 4 mm² in parallel (using both V- terminals)
  • Inter-panel data (DI + BI): 0.5 mm²
  • Falcon External Power: 0.75 mm²
  • Falcon V1/V2 GND: 1.5 mm²
Connectors:
  • Common GND backbone: copper busbar or high-current terminal block (>40A per terminal)
  • Per-row local busbars (V+ / V-): WAGO 221-413 (32A / 4mm² rated) — one cluster per PSU
  • Branch points to individual panels: WAGO 221-413
  • BI+DI bridge at first pixel: WAGO 221-412 or solder
Specific concerns I'd like feedback on:
  1. Falcon V1/V2 GND-only configuration: Is V1/V2 with GND but no +12V valid on the F16v5, or does the output driver circuit require V1/V2 +12V to function even when output V-pins are unused?
  2. Common-ground topology: Per-row V- busbars chained via a vertical backbone (functioning as the common ground reference). Sufficient, or should I bring all 4 PSU V- to a single physical star point instead?
  3. BI+DI bridge at first pixel: Any concerns vs. the more common BI-to-GND configuration? My reasoning: full redundancy from pixel #1 onwards.
  4. Wire gauges — is 2.5 mm² sufficient for the 4-panel string (20.5A peak), or should I move to 4 mm² for safety margin? Real-world load is 20–40% on average; full white is rare and brief in artistic content.
  5. WAGO 221-413 (32A / 4mm² rated) as branch connectors and per-row local busbars — appropriate for a 7-day continuous install, or should I use screw terminals for the higher-current branches?
  6. Falcon power source: Separate dedicated 12V supply for the Falcon, or tap from one of the panel PSUs (with appropriate fuse)? Concern: noise on the shared rail from heavy LED switching.
  7. Heat dissipation on mounting surface: Panels mounted on a wooden backing board (likely MDF or birch ply). Total dissipation ~1.7 kW peak across 65×170 cm. Do I need a thermal layer (aluminium sheet, thermal pad) between panels and wood, or can panels be glued directly to wood for a 7-day run at ~20–25°C ambient?
Better safe than sorry — appreciate input from anyone who's run similar high-current installations.
You are violating a very important rule. Where goes data, so goes V-. Your statement that DATA and BI cross a boundary without V-. You need at least a 22 AWG V- from the last pixel in one panel to the first pixel in the next panel.
I did not notice if you had V- coming from the controller along with the data lines. You must have data and V- going from the controller to the first pixel in the column.
Thanks a lot — you saved me from a real mistake. I was on the wrong track.
Schematic changes based on your feedback:
  • Falcon output: D and G active (was: only D)
  • From Falcon to first pixel: 2 wires (D + G), running parallel
  • At first pixel: D bridged to DI+BI, G to pixel GND
  • Inter-panel JST: 3-pole — DI, BI, signal GND (was: 2-pole, only DI+BI)
  • Power GND topology (busbars + backbone) stays as planned, runs in paralle
Really appreciate the clear explanation about why the busbar can't serve as the signal return path.
How big are the panels, and how long are the ground runs from the Falcon to the pixel panels through the G/DI/BI cables? And is one of the four Meanwells providing power to the Falcon, and if so, how long is the ground run from that Meanwell to the Falcon?
I would suggest that you build a full-scale, dimensionally accurate mockup of the display well in advance of the exhibition. The reason I say this is that one of the forum members (munu) had flickering problems with a somewhat smaller LED curtain for his garage, discussed in some threads back in September/November of 2024. This and this is another one of the threads.
Dimensions: L320mm(12.6'') x W80mm(3.15'') x H5mm(0.2")
GND from Falcon to panels, between 30-60cm.
And is one of the four Meanwells providing power to the Falcon - I will use an additional, separate power supply.
OK. I had some concerns about shifting ground signals causing data integrity problems, although your display is small enough that I'm dismissing those concerns.
Two last questions...
1) What is the distance from the power supplies to the display panels.
2) Can the data signals be run parallel to the power cables, rather than perpendicular?
A bit off-topic, but how are you mounting them? I have some flexible panels as well (16x16, 160mm X 160mm, ws2812, 5050), and I'm still thinking about how to mount them.
The power supplies are mounted on the back (wooden panel, plywood, 16/21 mm thick). Are you referring to the cable lengths? Those would be roughly between 15 and 50 cm.
As for the second question, I’d prefer that too, but the power distribution and the allocation of pixels per output led me to this structure. Off the top of my head, I don’t know how I could distribute it differently.
Good point! I always assumed these panels were self-adhesive, just like the strips themselves, but now I'm not so sure!
A friend who’s an electrician drew up a diagram out of interest in the project. Ignore the fans on the sides, because the design of the unit doesn’t allow for them. Ultimately, the controller will be at the bottom, as will the panel inputs. So the whole thing will be upside down on this diagram. On the back, my idea is to install only ventilation grilles at the top and bottom to create a chimney effect.
Are the cable diameters excessive? Is this diagram completely over the top compared to the first one? Or would you agree with this plan?
Openings on top? Are you in a never rains or snows situation? Are you going to provide a rain cover? Holes on the side with protective overhangs might be better
Back
Top
