Go Back   Do It Yourself Christmas Forums > Hardware > Renard > General
Reply
Thread Tools Display Modes
  #1
Old 03-17-2010, 06:18 PM
ncc1701mda's Avatar
ncc1701mda ncc1701mda is offline
Supporting Member
Default First RenSS16 Built but not working - Help!
I have completed the build on the first of four RenSS16 boards and everything seemed fine running through the beginner's setup guide (all test steps worked, LEDs lit when expected etc) up to the point where I progammed and installed the PICs. I started with the normal firmware compiled for PWM, connected it to my USB DMX Pro clone (RPM's) and ran a Vixen test sequence... Nothing. No LEDs blinking at all on the board. So I removed U6 and replaced it with a PIC programmed with the diagnostics firmware that uses an external osciallator - nothing. Reprogrammed the PIC with the internal oscillator firmware... thing. I put a logic probe on the clock input to the PIC and it is pulsing, same with the ZC signal. I don't have a scope to check signals with... I also replaced U2 as recommended in the troubleshooting guide - still dead. Any ideas on how to go about getting this working?
Mike
  #2
Old 03-17-2010, 06:23 PM
Wayne J's Avatar
Wayne J Wayne J is offline
Member
Global Moderator
Default Re: First RenSS16 Built but not working - Help!
Have you tried it straight from a serial port, not using the USB DMX?
__________________
http://jamesfamilychristmas.com/
Lighting up Mooresville with 500+ channels
Watch for the 2010 Downtown premier
  #3
Old 03-17-2010, 06:36 PM
ncc1701mda's Avatar
Supporting Member
Does the diagnostic firmware require a connection to a data source? I thought it would run on its own.
Mike
  #4
budude's Avatar
budude budude is online now
Supporting Member
You have to use the DMX code, not the Renard standard/diag code if using RPM's dongle. In addition - the pinout from the dongle to the RenardSS connector is not 1-to-1.
The dongle uses pins 1&2 for data and 7&8 for ground, the Renard uses pins 4&5 for data and 1&2 for ground. So something like this:
Dongle -> Renard
1 -> 4 (or 5) - Data A (or B)
2 -> 5 (or 4) - Data B (or A)
7&8 -> 1&2 - Ground
Sorry - I don't remember which is which with Data A/B on the Dongle - just swap the two pins around if it doesn't work. I can check when I get home as I have it running as we speak for my new project.
__________________
Plans for 2010:
32 Channels w/LOR1602W running DMX - complete (3rd year)
128 Channels w/Lynx FreeStyle running DMX with multiple 4/12-channel ACSSRs - complete (2nd year)
144 Channels w/Ren48LSD running DMX to drive RGB+W Super Strips and RGB Rainbow Floods - complete (1st year)
64 Channels w/Ren64 running DMX with LabRat DCSSRs to drive Phil's strobes - Ren64 complete (1st year), DCSSRs complete (2nd year)
25 RGB+W Super Strips - all original 19 updated with white LEDs, 5 more built with RGB - need UV/Orange LEDs
Full 2x2 LEDTriks Display (32x96 or 3072 pixels) - All panels (12), LEDTriks (4), Triks-C (4) complete and assembled - just need to box it up
4 Rainbow Floods - complete (1st year)
LEDs, LEDs... - figuring out what to do with 500 PLCC-6 LEDs...
25K Lights - mostly LED
Christmas in San Jose (ugliest site ever!)
  #5
Old 03-17-2010, 06:39 PM
ncc1701mda's Avatar
Supporting Member
The cable I built to connect RPM's USB-DMX does have the 1 to 4, 2 to 5 and grounds connected - verified that with an ohm meter. With the diag code nothing else is connected though - or is it supposed to be?
Mike
  #6
Old 03-17-2010, 06:47 PM
budude's Avatar
Supporting Member
I looked over a previous post I had and 1->4, 2->5 was for LOR which is backwards from Renard so I'm thinking it should be 1->5, 2->4 - easy enough to check.
You might try the beta-diag code - with nothing connected it will run through all your channels one-by-one (see the Wiki for details).
__________________
Plans for 2010:
  #7
Old 03-17-2010, 07:23 PM
ncc1701mda's Avatar
Supporting Member
Tried the beta diag code - no controller connected to serial or dmx - same thing - light string connected to channel 1 comes on as soon as power is turned on and never goes off - no HB - ZC - SD - FE - OE LEDs blinking. When running the diag code am I supposed to remove the second PIC (U7)? Edit> Removed the second pic - no change
Mike
  #8
Old 03-17-2010, 07:35 PM
stenersonj stenersonj is offline
Supporting Member
im sure you didn't do this but- when i tested mine for the first time i got what sounds like the same results. i had forgotten to put the jumpers on the board. i put them on and it worked great.
  #9
Old 03-17-2010, 07:37 PM
RavingLunatic's Avatar
RavingLunatic RavingLunatic is online now
Supporting Member
Quote:
Mike
Did the manual test of the LEDs/lights in the Beginner's Guide work?
Have you tried running the Beta code with the internal oscillator instead of the external?
In case you don't know how, change these lines:
__CONFIG _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _EC_OSC
;; __CONFIG _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTOSCIO
to
;; __CONFIG _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _EC_OSC
__________________
RavingLunatic
  #10
Old 03-17-2010, 07:39 PM
budude's Avatar
Supporting Member
OK - sorry - have to ask - is the PIC plugged in the right direction?...
I would check all around your Oscillator - make sure all the connections are good on that as well as to pin 2 on at least the first PIC. If nothing obvious, then a good check of all solder joints would be in order around the PICs. Check the voltage output of the regulator (3rd pin when looking straight at it) for 5v.
edit - also check pin 4 on the PIC (ZC in) - make sure it is not at 0v...
__________________
Plans for 2010:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
