| How To's Step by step project building instructions |
Thread Tools | Display Modes |
#1
Hi,
I got some LED's for a leaping arch. The distance between the LED's is 10cm. I wrapped them onto a bit of 1.5" diameter tubing as an experiment just to see what they looked like but I'm a bit disappointed with them because they seem a bit too spreadout and don't really give off a good glow. I was thinking about maybe wrapping two sets around one section of the arch and offsetting them a little (so effectively there is an LED every 5cm) but that means I need twice as many lights than I counted on. So what does everyone else who has LED arches do? How far apart are the LEDs on the string and what do they look like? Maybe thinner tubing might help a little bit? If you have any videos of your LED arches that I could take a look at that would be great. thanks, fj |
#2
Quote:
now personaly im going to have to wrap extra per segment eg might see what it looks like with 40 an then 60 leds per segment now having red,green,blue in a segment means alot of wires. the new style some people are trying with smd lighting looks like it will do a better job. http://doityourselfchristmas.com/for...ht=27+pin+plug is what i designed.
__________________
2010 Checklist: 256ch's - Working with Vixen 7x mini floods - awaiting on Red & Green Led Order now 4x Ren64 boards, 32x DCSSR's - All Completed, an Working More DCSSR's - On Order 10 Mini Trees - 0 Complete 3 RGB 9Ch Led Leaping Arches - 30% Complete, 1 arch completed 630Leds, 9 channels per colour Testing all Previous Lights - 0% Complete RGB inside plastic moulds - 0% Complete Small Mega Tree 5m - Needing Poles, Programming of Vixen - 0% done, 30% learned |
#3
Hey Fj,
One of the (many) things I have learned at this site was to fold a string in half offsetting the lights before wrapping something like an arch. That way you can reduce the spacing to 5 cm with the added bonus of a shorter string to wrap - if you have say a 10 m long dtring you effectively only have to wrap 5 m that way. |
#4
Quote:
don
__________________
2008: transitioned from X10 to Vixen + Renard (112 channels, banked out to about 200) 2009: chipiplexed Renard (224 channels) + non-chipiplexed Renard (112 banked out to ~200) 2010: garage door-triks, maybe prop-triks, retro-fit the Renard 112 for chipiplexing (a Renard 1K!) TBD; still lots of cool ideas floating around! this is getting way out of hand. http://www.eShepherdsOfLight.com |
#5
Quote:
i thought of a clear pcv pipe bend, an solder my own rgb leds, (simular project to the icle lights).
__________________
#6
Quote:
#7
Any type of opaque plastic sheeting would likely work. I've also heard of good results with the dryer hose.
don
__________________
| Thread Tools | |
| Display Modes | |
