Go Back   Do It Yourself Christmas Forums > General > Group Buys
Group Buys Group buys on parts/boards to save money for everyone
Reply
Thread Tools Display Modes
  #1
Old 02-08-2010, 05:00 PM
RichF's Avatar
RichF RichF is online now
Supporting Member
Default Ren24LV Parts coop interest
Now that the official Ren24LV PCB coop has started and I am participating in I am interested to know how many people would be interested in joining a parts coop for the ren24lv. As everyone knows there are savings to be found in coops and if there is enough interest I will be facilitating the coop.
If you are interested in joining and this is for planning purposes only please post the qty you would be interested in.
This is an interest only post at this time but if there is enough interest I will start one so we can finish the coop close to when the Ren24lv boards will be shipped.
Members Interested with Qty
Code:
tjetzer	2
richf	2
folksy	1
jondwste	1
bobkeyes	1
DIY Guy	2
Skunberg	3
Alanp	2
Chicken	6
tlorek	3
Mudsculpter	1
akonman	1
Dragon88	4
kychristmas	2
Billad	1
rdartist	10
mikeh65	1
cypress1138	6
rokkett	2
wirewrap	1
cpcoaster	2
mhuer	1
Code:
Current Ren24lv BOM:
1 838-3FD-316 "Power Transformers 16VCT@0.15A 8V@0.3A Dual Primary"
4 571-1-390261-5 "IC Sockets 18P ECONOMY TIN"
4 511-ULN2803A "ULN2803A Darlington Arrays Eight NPN Array"1
1 571-7969495 "Eurostyle Terminal Blocks 5.08MM VERTICAL 5P wire protector"
2 595-SN75176BP "RS-485 Interface ICs Bus Diff"
1 511-L7805CV "Voltage Regulators 5.0V 1.0A Positive"
1 821-DB102G "DB102G Rectifier Bridge 1A 100V
1 532-7136DG "Heatsink TO-220 VERT 19.7 TR"
3 271-27K-RC "1/4W 1% Metal Film Resistors 27Kohms 1% 50PPM"
4 271-1K-RC "1/4W 1% Metal Film Resistors 1Kohms 1% 50PPM"
1 271-120-RC "1/4W 1% Metal Film Resistors 120ohms 1% 50PPM"
1 625-1N4001-E3 "1N4001 Standard Rectifiers 50V 1A"
1 78-1N5239B "1N5239B Zener Diodes 9.1 Volt 0.5 Watt"
1 78-1N5229B "1N5229B Zener Diodes 4.1 Volt 0.5 Watt"
1 782-H11AA1 "H11AA1 Optocouplers Bi-Directional Input"
1 520-TCF1843-X "Full Size Crystal Clock Oscillators DIP-14 5V 18.432MHz"
1 140-HTRL25V1000-RC "Radial Electrolytic Capacitors 25V 1000uF"
2 140-HTRL25V10-RC "Radial Electrolytic Capacitors 25V 10uF"
2 534-3517 "Fuse Clips and Holders PC FUSE CLIP 5MM"
1 504-GMA-15 "5mm x 20mm Fast Acting Fuses 125VAC 15A Fast Acting"
3 579-PIC16F688-I/P "PICmicro MCUs 7KB 256 RAM 12 I/O"
4 604-WP63ID "LED Standard HI EFF RED DIFFUSED"
2 604-WP1503GD "LED Standard GREEN DIFFUSED"
5 271-680-RC "1/4W 1% Metal Film Resistors 680ohms 1% 50PPM"
5 581-SA105E104MAR "Axial Ceramic Capacitors 50volts 0.1uF"
1 571-9-146281-0 "AMPMODU Breakaway Headers 40 P HEADER GOLD"
7 571-2-382811-1 "AMPMODU MOD. IV Connectors ECONOMY SHUNT"
2 571-1-390261-2 "IC Sockets 8P ECONOMY TIN"
3 571-1-390261-3 "IC Sockets 14P ECONOMY TIN"
2 571-1-390261-1 "IC Sockets 6P ECONOMY TIN"
8 571-5556416-1 "Modular Jacks 8 PCB TOP ENTRY"
__________________
616 Dimming Channels
12 Ren-24s
13 Ren-24lvs
2 Ren-8ss
.2mW FM transmitter w/rds
More light bulbs then I care count.
http://www.vimeo.com/user1106747/videos
  #2
Old 02-08-2010, 05:19 PM
tjetzer tjetzer is offline
Supporting Member
Default Re: Ren24LV Parts coop interest
I'm in for 2 Rich.
Todd
  #3
Old 02-08-2010, 05:41 PM
folksy folksy is offline
Supporting Member
I would be in for 1 possible 2 depending on the cost.
  #4
Old 02-08-2010, 05:50 PM
jonedwste's Avatar
jonedwste jonedwste is offline
Supporting Member
I ordered 1 board, so I would for sure be in for one! If prices are low enough, I would do 2.
Jon
__________________
my List: (to do, done, ideas...)
  • 1 - Renard 24 SS (9 more to go, have all, just need to build)
  • LED icicles all hacked into short 3-4' sections for chasing, building an easy installation for these
  • on it's way 1000' of weather x zip wire-18g, green, Thanks Paul(CDI)!
  • on hand: 50 strings of 100ct clear lights
  • on hand: 50 strings of 100ct multicolor lights(ready to cut to 50ct's and swap bulbs for single colors, YIKES!)
  • on hand: 1000' weather-x zip wire, 18g, white(ready for projects)
  • 4 arches assembled and painted, 3 waiting for lights and 1 lit up!
  • 2 - Renard24lv pcbs & boms on hand, ready to build
  • 7 portaflood pcbs on hand, 1 enclosure on hand, 1200 LED's ordered
  #5
Old 02-08-2010, 08:24 PM
bobkeyes bobkeyes is offline
Supporting Member
I'm in for 1.
__________________
Bob Keyes
2009 (first year)-64 Channels, 8,000 lights
2010-256 Channels, 22,000 lights (I hope)
A mate that just keeps rolling her eyes
  #6
Old 02-08-2010, 08:32 PM
DIY Guy DIY Guy is offline
Supporting Member
I'm in for 2.
Will this include the on-board transformer? I'm powering mine with external transformer. Either way, count me in!
  #7
Old 02-08-2010, 08:35 PM
Skunberg Skunberg is offline
Member
At least 3 kits.
__________________
2010 - 104 channels of ???
  #8
Old 02-08-2010, 08:40 PM
alanp alanp is offline
Member
Hi Rich, I would like two. Thanks
  #9
Old 02-08-2010, 09:14 PM
chicken chicken is offline
Supporting Member
I purchased 6 of the LV boards and 28 of the normal HC ones (need to build a bunch of myself and some family members) If the price is cheap enough I am interested, otherwise I think I can get a decent price direct due to the amount of boards I need to build.
  #10
Old 02-08-2010, 09:36 PM
tlorek tlorek is offline
Member
I'd be up for 3.
__________________
Tom
Christmas on Victory Celebration of Lights (under construction)
2009 (1st year) - 328 channels, 48,500 lights
2010 (2nd year) - 448 channels (min), 61,100 lights (min)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
