Go Back   Do It Yourself Christmas Forums > Hardware > Development
Reply
Thread Tools Display Modes
  #1
Old 09-14-2009, 09:24 PM
dirknerkle's Avatar
dirknerkle dirknerkle is offline
Supporting Member
Default Renard-WC Wireless Controller
This thread previously was "XBee Wireless Modules" in the Development forum. Now that the gizmo is almost in finished form, I thought it would be helpful to move it here. I'm sure the mods will correct me if I'm wrong!
The Ren-WC works very well, but I haven't yet tested in-the-field performance when everything is mounted inside the protective cases, etc. I also will be testing effective range for both the regular XBee module and the higher-powered XBee Pro.
So right now I'm looking for feedback on the documentation -- it's not 100% complete yet, but it's only missing the final BOM and circuit board tracing. I believe the PDF will give readers a pretty solid understanding of how it works, how to build and configure it, costs, and hopefully I've already answered most of the important questions via the Q&A at the end.
Specifically I'm looking for suggestions, comments, criticisms, or items that are just plain oversights. It's always better to catch them now before the project is released.
Thanks in advance for everybody's help!!!
__________________
dirknerkle
...your one-stop shop for Exomount Technology...
Last edited by dirknerkle; 09-28-2009 at 11:19 PM. Reason: Removed out-of-date PDF file
  #2
Old 09-14-2009, 09:36 PM
thuddman thuddman is offline
Member
Default Re: Renard-WC Wireless Controller
Hey, nice job! Now I can control my neighbor's lights across the street!
Looking forward to hearing how it works in practice...
  #3
Old 09-14-2009, 09:39 PM
Wayne J's Avatar
Wayne J Wayne J is offline
Member
Global Moderator
Same here. My neighbor said I could decorate the trees lining his yard, I just haven't wanted to run the cable.
__________________
http://jamesfamilychristmas.com/
Lighting up Mooresville with 500+ channels
Watch for the 2010 Downtown premier
  #4
Old 09-14-2009, 10:33 PM
oldcqr oldcqr is offline
Member
Sweet!
My only suggestion would be to change the silk screen for C3. Add that nifty little wider boarder on the - side. I know the + side is marked (silkscreen and square pad), but that wide mark has saved me a couple of times
__________________
-Mike
www.LandoLights.com
www.SequenceCenter.com --> Vixen Sequences and More
  #5
Old 09-14-2009, 10:45 PM
FireGod's Avatar
FireGod FireGod is offline
Member
DIYC Moderator
I am currently running an Xbee Pro in my rotating Christmas tree on the FGII board. It works perfectly so far even while rotating.
__________________
384 Channels hardwired, 32 wireless
  #6
Old 09-14-2009, 11:14 PM
Wombat Wombat is offline
Member
That looks great. very simple design and modular and flexable. Well done
Wombat
__________________
Have a Wombat of a Christmas
64 Channel own design 595 (2006)
128 channels 595 32 Channels 2xren16's (2007)
64 Channel Mega Tree (2007)
2006 Display Video:http://www.youtube.com/watch?v=_-4cyhEdrHY
2008 WomPanel (LEDTRIX on steroids) http://www.youtube.com/v/-5L6_TQPKnY
2008 Display Video:http://www.youtube.com/watch?v=6wZFp861wbQ
2009 Display Video:http://photos.newsys.com.au/Christma...10767134_Jgf57
  #7
Old 09-14-2009, 11:34 PM
FireGod's Avatar
Member
DIYC Moderator
I am using Mouser# 888-XBP24-ACI-001J
I do not recommend the model with the whip antenna. I have already broken one off and it increases the height.
__________________
  #8
Old 09-14-2009, 11:53 PM
dirknerkle's Avatar
Supporting Member
Are you using the Japan version because of its 10mw power rating instead of the 50mw version? (Do you have to program it in Kanji? ... just kidding...)
I have a few mixed feelings about the 1" whip antenna too -- it's just "out there" and seems a bit easy to bend or, as has happened to you, break off if you're not careful. And I'm not sure how the height will work with the boxes we generally use -- perhaps I'll mount it on the TOP cover and let the antenna point down toward the SS controller. Whether the upside-down orientation will matter is part of my testing, too.
I'll have to order out a couple on-chip antenna units to see how they fare.
Good luck on your mini! Wish I could be there.
__________________
dirknerkle
  #9
Old 09-15-2009, 12:05 AM
budude's Avatar
budude budude is offline
Supporting Member
I have my Helix with the XBee mounted in a CG-1000 box and I bent the antenna "up" (with respect to the box) and it seems to fit/work pretty well. I've bent it back and forth a few times through a couple removes/installs and it's stayed on so far but have to agree that it probably can't take a lot of punishment...
__________________
Plans for 2010:
32 Channels w/LOR1602W running DMX - complete (3rd year)
128 Channels w/Lynx FreeStyle running DMX with multiple 4/12-channel ACSSRs - complete (2nd year)
144 Channels w/Ren48LSD running DMX to drive RGB+W Super Strips and RGB Rainbow Floods - complete (1st year)
64 Channels w/Ren64 running DMX with LabRat DCSSRs to drive Phil's strobes - Ren64 complete (1st year), DCSSRs complete (2nd year)
25 RGB+W Super Strips - all original 19 updated with white LEDs, 5 more built with RGB - need UV/Orange LEDs
Full 2x2 LEDTriks Display (32x96 or 3072 pixels) - All panels (12), LEDTriks (4), Triks-C (4) complete and assembled - just need to box it up
4 Rainbow Floods - complete (1st year) - working on 6 MM with CC as well...
12 or 20 n1ist SMD LED strips - waiting on coop...
25K Lights - mostly LED
Christmas in San Jose (ugliest site ever! - no really!)
  #10
Old 09-15-2009, 12:54 AM
sjwilson122 sjwilson122 is online now
Member
WOW! This looks sweet. Looks very simple, documentation is outstanding so far! This would save people alot of cat5 runs and make decorating things much easier. Great job!
Reply
Tags
ren-w, xbee
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
