Go Back   Do It Yourself Christmas Forums > Learning center > How To's
How To's Step by step project building instructions
Reply
Thread Tools Display Modes
  #1
Old 07-29-2010, 06:00 PM
quefol quefol is offline
Member
Default connecting multiple controllers
i have a question for someone that has expieance in hooking up multiple controllers i have one olson 595 with ren-c a led tricks with parallel port connection an now i am in the process of building a ren 24 i only have one serial connetion and one parallel port on the back of my pc how do i connect everything to work together with the same sequence in vixen
  #2
Old 07-29-2010, 06:28 PM
Penfold's Avatar
Penfold Penfold is offline
Supporting Member
Default Re: connecting multiple controllers
What you can do is get a Serial card like the one you can find at MJPA, link below:
http://www.mpja.com/prodinfo.asp?number=12765+DC
Or you can also get a USB to Serial converter that you can find online. An example would be like this one:
http://cgi.ebay.com/ADAPTER-CABLE-SE...item5ad94ae1d0
After you get a couple of new ports in place it's just a matter of making sure you have the plugins selected in Vixen.
__________________
2009 Plan: 4 Ren24 88 channels of blinky goodness! (84 channels will be run and have 12 as backups for now)
2010 Plan: Hoping to maybe break the 100 channel marker.
  #3
Old 07-29-2010, 06:48 PM
Mudsculpter's Avatar
Mudsculpter Mudsculpter is offline
Supporting Member
I have one of these and this is much more reasonable.
http://cgi.ebay.com/Smartio-MOXA-8-P...item53db8574f5
__________________
Regards,
Chuck
  #4
Old 07-29-2010, 07:13 PM
Penfold's Avatar
Supporting Member
WoW! thanks for posting that little gem Chuck that got me drooling. I didn't know that there was a much cheaper card! COOL!
__________________
  #5
Old 07-29-2010, 07:24 PM
XmasInGalt XmasInGalt is offline
Member
That's the same card I've had in my machine for the last two years. I've used up to 5 ports during a show without any problems.
__________________
160 Channels in 2007 (Olsen 595s & REN16s)
336 Channels in 2008 (Olsen 595s with REN-Cs & REN16s)
336 Channels in 2009, LedTriks (1x2), RDS
384 Channels in 2010
8 Renard 16s (xmus) with Ren-Ws
4 Olsen 595s with Rec-C/Ren-Ts
LedTriks (1x2),RDS, Video
  #6
Old 07-29-2010, 08:43 PM
Member
i have tried a usb to serial connector on my ren c but dosent want to work very well channels like to flicker on an off randomly is there settings i need to change
  #7
Old 07-29-2010, 08:56 PM
Supporting Member
I tried the USB to serial connector method first and it was a waste of time for me.
If you have a PC for your show computer with an open PCI slot you are better off getting a MOXA multi port when they come available.
__________________
Regards,
Chuck
  #8
Old 07-29-2010, 09:07 PM
oldcqr oldcqr is online now
Member
<< this.
Last year I was having problems with Vixen and 'access denied' errors (someone please correct me). Others commented that they only see that problem when using USB to RS232 adapters, so I went ahead and purchased a cheap ($12) 2 serial port PCI card for this year. Hopefully this new card will clear up that error.
Monoprice has them for a buck cheaper, but I can't recomended them any more. They've screwed up 4 of my last 11 orders - 3 were missing stuff, and the last one they sent wrong stuff.
__________________
-Mike
www.LandoLights.com
www.SequenceCenter.com --> Vixen Sequences and More
  #9
Old 07-29-2010, 11:07 PM
Supporting Member
During setup I usually have the same errors. I can't really explain why it happens though. A reboot clears things up.
__________________
Regards,
Chuck
  #10
Old 07-30-2010, 10:37 AM
Member
For me, a reboot fixes the problem for a random amount of time -- 1 day to more than a week. Then it shows up again.
__________________
-Mike
www.LandoLights.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
