Go Back   Do It Yourself Christmas Forums > Hardware > Renard > General
Reply
Thread Tools Display Modes
  #1
Old 07-29-2010, 01:30 AM
smartalec smartalec is offline
Member
Default My ren64's are dieing
In feb this year i brought 4 ren64's, i had them all hooked up an they looked great blinking an flashing for 1 month on my bench.
then i turned them off, an when i switched them on an i was surprised non of them worked, i then replugged the rs485 line into one of the ren64's an the other 3 worked.
just the other day i was using a ren64 by itself, switched it off, switched it on 24hrs later, at it does'nt work now either.
so now i have 2 ren64's that dont want to work.
is there any testing procedure to help work out what has happened to these 2 ren64's.
as i would hate for another one to die on me.
thanks alec.
__________________
2010 Checklist:
256ch's -
Working with Vixen
7x mini floods - awaiting on Red & Green Led Order now
4x Ren64 boards, 32x DCSSR's - All Completed, an Working
More DCSSR's - On Order
10 Mini Trees - 0 Complete
3 RGB 9Ch Led Leaping Arches - 30% Complete, 1 arch completed 630Leds, 9 channels per colour
Testing all Previous Lights - 0% Complete
RGB inside plastic moulds - 0% Complete
Small Mega Tree 5m - Needing Poles,
Programming of Vixen - 0% done, 30% learned
  #2
Old 07-29-2010, 01:42 AM
budude's Avatar
budude budude is offline
Supporting Member
Default Re: My ren64's are dieing
Can you clarify what you mean by not working? Symptoms?
__________________
Plans for 2010:
32 Channels w/LOR1602W running DMX - complete (3rd year)
128 Channels w/Lynx FreeStyle running DMX with multiple 4/12-channel ACSSRs - complete (2nd year)
144 Channels w/Ren48LSD running DMX to drive RGB+W Super Strips and RGB Rainbow Floods - complete (1st year)
64 Channels w/Ren64 running DMX with LabRat DCSSRs to drive Phil's strobes - Ren64 complete (1st year), DCSSRs complete (2nd year)
25 RGB+W Super Strips - all original 19 updated with white LEDs, 5 more built with RGB - need UV/Orange LEDs
Full 2x2 LEDTriks Display (32x96 or 3072 pixels) - All panels (12), LEDTriks (4), Triks-C (4) complete and assembled - just need to box it up
4 Rainbow Floods - complete (1st year) - working on 6 MM with CC as well...
12 or 20 n1ist SMD LED strips - waiting on coop...
25K Lights - mostly LED
Christmas in San Jose (ugliest site ever! - no really!)
  #3
Old 07-29-2010, 01:50 AM
g2ktcf's Avatar
g2ktcf g2ktcf is offline
Supporting Member
Location: Pearland, Tx (sometimes) and anywhere on the globe the rest of the time
I hate to ask this question...but it sounds like a power problem.
What transfomer are you using?
__________________
2008 - 64 Dimmable Channels with REN64 XC
2009 - Work Destoyed all Blinky Flashy...Small Static Display (thanks to my wife and son)
2010 Plans:
2 - REN64 XC completed!
12 - REN24 completed!
2 - FireGod128 completed!
80 - SSRez (in progess at 45%)
1 - Helix (in progress 90%)
10 - Portafloods (in progress 90%)
4 - LED Tricks/Tricks-C (in progress 90%)
1 - Pira.cz Xmitter/Stereo Ecoder/Compressor-Limiter (in progress 20%)
1 - AIOT (in progress 20%)
  #4
Old 07-29-2010, 01:53 AM
Member
Quote:
i plug the power in, all the leds quickly flash like they normaly do when powered up, an thats it, nothing else.
nothing is working beyond that,
i dont have a pic programmer (got the pics pre programmed)
its like it just does'nt want to do anything else.
thats why i asked is there testing procedures i can do to try an track down the fault im experancing.
thanks for the fast reply
alec
__________________
2010 Checklist:
256ch's -
Working with Vixen
  #5
Old 07-29-2010, 01:57 AM
Member
well thats a funny question, reason is the follows
i have a 6.3v AC transformer for all the ZC circuit,
an i have a computer power supply to run the board.(removed the regulator)
so when i tested the board to a working one, they were both using the same power source
__________________
2010 Checklist:
256ch's -
Working with Vixen
  #6
Old 07-29-2010, 02:24 AM
g2ktcf's Avatar
Supporting Member
ok, I would start by getting a diagnostic FW chip in and making sure that your oscillators and PICs are talking properly.
__________________
2010 Plans:
  #7
Old 07-29-2010, 02:30 AM
Member
bugger i was hoping i would'nt have to do that.
no pic programmer yet.
is there any other tests i can do with the multimeter?
__________________
2010 Checklist:
256ch's -
Working with Vixen
  #8
Old 07-29-2010, 02:38 AM
g2ktcf's Avatar
Supporting Member
well, start checking your power rail for one. Make sure that your PC supply is giving you 5 volts. Also, make sure that GND is actually GND. Thats about all you are going to do with DMM. Is your power led on?? if so, check the voltage across it.
__________________
2010 Plans:
  #9
Old 07-29-2010, 02:57 AM
Member
yer power supply is working fine the power light lights up
even the dcssr's leds light up (there not connected to anything else)
if like there working, i disconnect it for X amount of time then they dont start back up again.
__________________
2010 Checklist:
256ch's -
Working with Vixen
  #10
Old 07-29-2010, 03:00 AM
g2ktcf's Avatar
Supporting Member
well you need to wait for your programmer IMHO. With that, we verify the osciallator and the internals of the PICs. And, you may have had some surge that zapped the programs.
__________________
2010 Plans:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
