| How To's Step by step project building instructions |
Thread Tools | Display Modes |
#11
Why not just hook up the ren 24 to the serial port and the daisy chain the ren-c on to the Ren 24. You can run 256 channels on one serial port.
#12
I have to agree with cobraman44, why do you want to run each controller off of it's own port? I think the solution you are looking for is called "Daisy Chaining".
__________________
Ricky, Jrd Over 6,200 lights, controllable by a man throwing two breakers to the music - Hoping to change that this year. My website - My Outdated blog |
#13
is the data pin configuation the same on the ren c as the ren 24 v3.0 i thought there were diffrent on the rs232 dosent the ren 24 have its own power supply and zero cross so what happens to the zero cross coming from the ren c
#14
They should work fine together depending on which version of the Ren24 you have, The ZC signal from the Ren-C would be ignored. Actually if you had the Ren 24 version 3.0 or higher inline before the Ren-C then it would pass down ZC and power according to the wiki but I am not sure which pin the power would be on.
__________________
#15
Quote:
#16
Has anybody tried a card like this? It says it will output RS-485. Neither of my computers have com ports so right now I'm just using a USB adaptor for my laptop for my Renard.
http://www.newegg.com/Product/Produc...-067-_-Product |
#17
Quote:
I have not used this one in particular but the individual reviews would steer me away from this device.
__________________
Regards, Chuck
#18
One of the *approved* USB to RS485 adapters is a Hexin and currently sells for about $12 delivered. Use a powered USB hub and plug a bunch of them into the hub for a pretty easy and inexpensive way to quickly add capacity.
__________________
dirknerkle ...your one-stop shop for Exomount Technology... |
#19
That looks much better, I'll have to look for one. Thanks
| Thread Tools | |
| Display Modes | |
