Results 1 to 10 of 28
Thread: Home Etch Grinch file
    Mooresville, NC
    7,636
    Default Home Etch Grinch file
    Yes, the Grinch is available for home etch. ;) I have made several of them.
    Attached is the .pdf of the trace transfer file. and a photo of the assembly. Note, there are a ton of jumper wires. If you are comfortable with 2 sided etching, then I have those files also.
    8)
    Attached Files Attached Files
    Denmark
    3
    Default
    Hi
    Thank's a lot, i'll go for the one side pcb, even its with more jumpers, but, a lot more easy to do, than the dubble side one, when you do it in the kitchen. Don't tell my wife :-).
    Brgds
    Finn
    Xmas light forever
    Oct 2007
    Oregon USA
    14
    Default
    I'm kinda new i can solder a board but I lack in lingo. The jumpers you are talking about are they from holes drilled through the board and soldered?
    CJA
    <img>
    Mooresville, NC
    7,636
    Default
    Quote Originally Posted by Cliffiv
    CJA
    In the picture, the traces in red, is point to point wires (jumpers) and yes, the board gets drilled for the wires as it does the componnents.
    Tampa, FL
    110
    Default
    Wayne I noticed your schematic does not have the LED, power in plug and jumper as in the coop board.
    http://www.doityourselfchristmas.com....php?pic_id=17
    Mooresville, NC
    7,636
    Default
    Quote Originally Posted by jmelvin
    That version was one of the first ones I did so they could be made for testing, and is the easiest to home etch. I bring power in on the RJ45. The power led is an option I didn't use at the time. Jumper?
    But...
    If you would like the high end version....
    the prototype without the power connector.
    Washington State
    4
    Default
    Wayne, I would like the double sided file. I have done Dbl sided boards a few times. Though tricky to line up, it makes for a nicer looking board.
    thanks
    Mooresville, NC
    7,636
    Default
    Here is the files for the traces and parts for the double sided Grinch in the above post. There are a bunch of 'vias' on this board. If you plan to etch one, study it closley. I put quite a few of them under the IC sockets, so they are not visible when completed.
    8)
    New Hampshire
    487
    Default
    The double side grinch, works GREAT. Nice job Wayne.
    Pete
    [size=4]How-to/Can-do Wisdom[/size]
    Always endorse the 10% rule...Always attempt to be 10% smart then that you are working on.
    The Dumbest Question...Is the one never asked.
    If you find it uncomfortable to use something... Try turning them around.
    Remember a Match can burn twice.
    148
    Default Re: Home Etch Grinch file
    Hi there, this is my first post here so please let me ramble for a moment.
    I downloaded the file: grinch1b_156.pdf a while back and finally made the PCB, using Press-n-Peel,
    I have all the parts (but it seems for a "newer version", and I am using the Allegro A6279EAT,
    (Big thanks to the folks who suggested I ask for free samples!! And defiantly BIG thanks for all the info here and files!!!).
    I found the "how to" for v10 but not the version I am using.
    Here is the big question: where are the assembly instructions/steps for "this" file: grinch1b_156.pdf?
    I'm just the type of person who needs the full instruction set so...
    Please help.
    In closing this is some of the coolest stuff I have ever found on the web!
    Thanks to everyone, I love reading up on this subject and have jumped in
    (though maybe a bit too far as I can't even figure out the easy board).
    P.S. an FYI, the link on the "Start here if new to the grinch" page does not work any more.
