Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Led Lights wont fade they just flicker
    Dec 2008
    Keaau, HI
    219
    Default Re: Led Lights wont fade they just flicker
    I was able to fix this problem with a single 47k ohm resistor (1W rating).
    More info here:
    http://forums.planetchristmas.com/sh...ad.php?t=39193
    Aug 2007
    Medford, ny
    770
    Seen crazylights info but says you could use other resistors which one would i use from mouser. and will it dim for most led's for dimming?
    May 2008
    Chattanooga, TN
    47
    Also check to see if your LOR controller firmware is up to date. New firmware to assist with LED dimming was released some time ago.
    If you are using LOR S2 ver 2.8.12 then it contains the lastest firmware that you can then use the hardware utility to reflash the firmware for your controllers.
    (I have 480 channels of LOR and 41,000 full wave LED lights and they dim great, do not need to use terminators on mine)
    [SIZE="1"][/SIZE]John
    [SIZE="2"][SIZE="1"]480 LOR Channels, 2 CCRs, 8 Mighty Minis, 10 Rainbow Floods, 1 Vflood and Vdrive, 0ver 40,000 [/SIZE][SIZE="1"]LEDs[/SIZE][/SIZE]
    Aug 2007
    Medford, ny
    770
    im using renard boards
