Results 1 to 10 of 11
Thread: Ren24LV and the SSREz
    1,177
    Default Ren24LV and the SSREz
    I am having a difficult time understanding where my issue is trying to dim (without flickering) using my Ren24LV in combination with the new SSREz. Has anyone actually used this combination yet? I get a flickering at any intensity value under ~80% all the way down. No flickering at 100% at all. My SSREzs have the triacs oriented with the tabs toward the inside of the board (opposite the screening) so I think I am okay there. Maybe I just need a better understanding of the Ren24LV. I am taking the Renard-20071229.asm file and making two edits for use in my Ren24LV with SSREzs connected:
    #define PWM_build 0
    changing to
    #define PWM_build 1
    and
    #define OUTPUT_NEGATIVE_TRUE
    (I am removing this line all together)
    With this setup I get all 4 red LEDs on the Ren24LV to light but I don't seem to have any control of the board via the RS485. With the PICs that cause the flickering I communicate fine but I don't get the results I desire.
    Has anyone actually used this setup?
    PS: same lights dim as expected using my standard Ren24s.
    Ahwatukee (Phoenix), AZ
    1,994
    Default Re: Ren24LV and the SSREz
    I have 23 SSR EZ's connected to Ren24 LV's They are boards that have both individual LEDs and also SSR's on them.
    Hardware is configured as follows - external 5v supply, DB102 removed, transformer connected, and H11AA11 installed.
    I am using this firmware to run them.
    http://www.kostyun.com/FIRMWARE/Rena...24LV-DC-ZC.zip
    Virginia Beach, VA
    1,333
    Virtus. Built up a SSRez over the weekend and had it testing for a day or so and no flicker.
    More channels then I can use.
    More light bulbs then I care count.
    [url]http://www.vimeo.com/user1106747/videos[/url]
    1,177
    Thanks, Rich. I was able to 'harvest' some of the EZs from the snow this weekend but your test leads me to believe I need to look more closely at the LV rather than the EZ.
    Jun 2009
    Ottawa, Ontario, Canada
    2,845
    Quote Originally Posted by Virtus View Post
    Any chance you have the wrong ZC chip? (I did this on one board once.. )
    There's a similarily numbered part that works for DC not AC, thus you only get ZC 50% of the time. H11A1 vs H11A11 (as I recall..)
    1,177
    I will double check. Thanks for the idea. I suspect that is what Frank was alluding to above, too, upon second reading.
    Virginia Beach, VA
    1,333
    What firmware are you using.
    I see you selected PWM enabled so why not disable PWM since your running all incandescent lights.
    1,177
    The issue was firmware. I spent several hours programming and testing many versions until I got a set of 6 PICs that behave just as they should. This is going to make for a lot more channels this year...48 more actually!
    Jan 2010
    Meridian, ID
    1
    Reviving an old thread looking for help. I ordered up a couple of Ren24LV's from Radiant and got them built last weekend. I'm struggling to get a firmware built that works with this board. Frank's site is no longer hosting the firmware and I can't get the right settings to get Vixen to communicate with the boards. I have tried out making changes similar to this thread on the renard-20071229.asm without any success. I do have the diagnostic firmware (ren-diag-20070815a.asm) working...up to the point of communicating with the PC. Then I have channel 6 on regardless of whether I'm sending a Vixen signal or not. I tried out the same diagnostic firmware and Vixen setup with a Ren24 and everything works so I suspect I have some tweaking to do in the firmware to make it work with the LV.
    Does anyone have a working asm or settings that they could share that might help me out? I'm running the transformer - so it's AC and I'm driving DirkCheap SSRs.
    Sep 2009
    Omaha, Ne
    3,145
    Quote Originally Posted by BSPBimmer View Post
    Looking at the Wiki page for the Ren24LV you need to make the changes to the ASM file listed under the Firmware heading.
