Results 1 to 2 of 2
Thread: Distance limitation between Field module and SSR
    Dec 2008
    Riverview, FL
    41
    Default Distance limitation between Field module and SSR
    What ist he estimated max distance between Field module and SSR? I have a couple runs that will approach 50' and I only need a few channels in that area so I don't want to dedicate a whole field module to that area.
    The max reliabile distance may dictate how I route my cables.
    Thanks for any input.
    Tulsa, OK
    128
    Default Re: Distance limitation between Field module and SSR
    I'm not the expert on this, but the cable from the field module to the SSR carries voltages that turn the SSR on/off/dim. I'd think that as the runs got longer, wire resistance would tend to drop those voltages. With that being said, I've got a few runs around 50', and have no problems.
    You also might consider upping the voltage regulator in the computer interface to 6v. Give this one a try.
    [CENTER] Visit us at [URL="http://www.tulsaxmas.com"]www.TulsaXmas.Com[/URL][/CENTER]
    [CENTER]
    [/CENTER]
