Results 1 to 10 of 13
Thread: Thwarted by the smallest strand
    Hanover PA
    443
    Default Thwarted by the smallest strand
    Ok, Simple Simple thing.
    Wife has a 25 count strand of regualr minis. with ghosts on each light.
    Lights stopped working.
    Tried the light keeper pro a dozen times, nothing.
    Checked every single bulb and they all work.
    Used voltage detector and I have voltage everywhere on the string.
    (Even pulled apart the 2 lines at the start a foot apart and both sides have voltage.)
    Checked fuses.
    Thoughts?
    I hate being stumped by small things.
    UPDATE:
    (Don't remember if i tried light string in different outlet at this point.)
    Re-examine fuses and see 1 little wire in fuse block that looked like it might snake around to the other terminal.
    Get rid of that wire.
    Plug lights into different outlet and they work.
    Then back to the bad outlet, and they don't work, go back and forth 3 times and bad outlet never works.
    So two different voltage detectors (1 light keeper pro and 1 good one) both detected voltage on bad outlet.
    Grab voltmeter and get nothing on bad outlet?
    Grab wireing check cube thing (Thing with 3 leds and tests GFCI's)
    I think it showed hot and ground reversed (Leds did light. I could be reveresed on colors, didn't watch very long.)
    Press test button, leds go out.
    5 minutes later i finally found the GFCI.
    (The bad outlet is in first floor bathroom, for some reason GFCI is located in master bedrooms bathroom upstairs?)
    Probe all outlets on circuit and get nothing.
    Reset GFCI and everything is fine. Bad outlet now works.
    Any thoughts on what happened?
    (Maybe the little wire barely shorted things, somehow kinda half tripping the GFCI resulting in slight hot to ground but not tripping curcit? That just sounds odd?)
    Everybody else as thouroughly confused as i am?
    Now i am worried about my house wireing or the GFCI in the bathroom.
    1,746
    Default Re: Thwarted by the smallest strand
    Quote Originally Posted by lboucher View Post
    By "nothing", do you mean that it shows that a voltage drop is present, or that it shows no voltage drop is there?
    Did you check them using Light Keeper, or some other steps?
    25 count is an unusual number for U.S. Usually it is multiples of 20, 35, or 50. Are those bulbs all in series, or is it some other configuration? (how many wires run between each bulb to the next?)
    don
    Click for display details >>
    Hanover PA
    443
    don
    Sorry
    By nothing i meant i pulled the trigger a dozen times, and lights never lit up.
    Checked bulbs using light keeper pro.
    Maybe its a 20 count strand, didn't count exactly.
    See update to my post
    Jun 2009
    Ottawa, Ontario, Canada
    2,496
    Sorry
    Don't know about in PA, but in our local area having the GFCI in one bathroom, with "other" bathrooms downstream is considered perfectly acceptable to code.
    So I wouldn't worry too much about the house wiring. I would focus on the GFCI monitoring ... do these actually leak slightly when tripped? The easy test would be to trip another unit (assuming you have one in the kitchen??) and test there.
    In PA, it's ok to have multiple bathrooms running off of a GFCI. The circuit going to that GFCI must be dedicated though. (No lighting circuits or other types of circuits other than downstream outlets)
    48 Channel Olsen 595
    16 Channel Renard XMUS
    64 Channel Renard XB
    25,000 Lights 2009
    4 Mega Trees, 5 Arches
    www.AltoonaLights.com
    I would bet you have conduit and one of the sections are not screwed together properly, this is real common, I always run a seperate ground wire, as its much better, as if the conduit connectors aren't connected properly, either tightened too little and the thing slips or tightened to much and the screw strips in the zink coupler and the conduit slips, either way ground connection doesn't carry current, best fix is push a seperate ground wire threw the conduit and connect it at each outlet, GFI's only work right if ground connection is good, otherwise they won't save you, so this needs to be fixed, you could also remove the gfi in the bathroom, put in a regular two prong outlet and put a gfi breaker in the fuse box, then the ground would be good to the gfi and it would work right.
    I think having seperate gfi's in each area is better though, just a bit of extra protection.
    Long Island
    460
    Also remember GFCIs are not infallible. A GFCI costs $15 at the big box, a gfci breaker is $60. Both are rated for 15A.
    Typically when they fail you can't reset them, but you never know.
    Dec 2008
    Pensacola, FL
    895
    Quote Originally Posted by D_E_H0987 View Post
    What you described earlier, (the little wire shorting the hot to neutral) will not cause a GFCI to trip. The GFCI will only trip if the current through the hot lead is not equal to the current in the neutral lead. That is the definition of a ground fault. YOU DO NOT HAVE TO HAVE A GROUND LEAD FOR A GFCI TO WORK PROPERLY!!! Only an imbalance in the hot and neutral currents will cause a trip. If you get across the hot and neutral lines, without a ground path through your body, you will sit there and fry unless you trip the panel's (20 amp or so) breaker. The GFCI will not (and should not) trip.
    Longfellow said that in this world a man must be either anvil or hammer.
    But some are neither, they are merely bellows.
    Quote Originally Posted by WireWrap View Post
    I don't want to get into a big argument over this.
    But how can you tell if something is conducting to ground if you don't have a good ground referance?
    I wouldn't want to bet my life on the house wireing, what if its screwed up and the white wire is screwed onto the copper screw rather than the silver one?
    Anyway just a couple of thoughts on reasons for a proper ground connection, but if you want to die go ahead, no skin off my back.
    Dec 2008
    Pensacola, FL
    895
    That's not the impression you're giving, looking at your last statement.
    That's not how a GFCI works. Try re-reading the explanation I gave in the previous message. If the GFCI detects a difference between the hot circuit and the neutral wire of approximately 5 ma (five-thousandths of one amp) it ASSUMES the possibility of a fault and removes power to hopefully save a life.
    Here's a little more information: http://ecmweb.com/mag/electric_gfci_basics/
    That's why you should only work with house wiring if you KNOW what you are doing and how to properly test for correct wiring. In the example you suggest, with the neutral tied to the hot outlet screw: I would have to assume that you are also suggesting the the hot (black) lead is connected to the silver contact. If this was a GFCI outlet, this would still trip IN THE EVENT OF A GROUND FAULT in the downstream wiring, as the difference in current between the hot and neutral conductors would open both sides of the circuit.
    A GFCI will NOT trip in the event of a short circuit, where the current is only flowing in the hot and neutral conductors. As long as it remains equal, the GFCI is not tripped.
    And no brain in your head, either. Still waiting to see evidence of the few thoughts... There are many reasons for proper grounding, but they are delineated in the National Electrical Code, not your imagination.
    Note my signature:
