Results 1 to 6 of 6
Thread: Need help
    Default Need help
    I was working on a project for halloween. Needless to say that my computer crashed. When
    I went back to working, vixen wouldn't work anymore. I then proceeded to reload. Now I get this message when I try to open my sequence.
    If anyone can point me in the right direction to fix this i would be very happy.
    Thank you in advance.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Xml.XmlException: '.', hexadecimal value 0x00, is an invalid character. Line 139, position 515657.
    at System.Xml.XmlTextReaderImpl.Throw(Exception e)
    at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
    at System.Xml.XmlTextReaderImpl.ThrowInvalidChar(Int3 2 pos, Char invChar)
    at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
    at System.Xml.XmlTextReaderImpl.ParseText()
    at System.Xml.XmlTextReaderImpl.ParseElementContent()
    at System.Xml.XmlTextReaderImpl.Read()
    at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
    at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
    at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
    at System.Xml.XmlDocument.Load(XmlReader reader)
    at System.Xml.XmlDocument.Load(String filename)
    at Vixen.EventSequence..ctor(String fileName)
    at StandardSequence.StandardSequence.Open(String filePath)
    at Vixen.Form1.OpenSequence(String fileName)
    at Vixen.Form1.openALightingProgramToolStripMenuItem_ Click(Object sender, EventArgs e)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.190 (QFE.050727-1900)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Vixen
    Assembly Version: 2.1.3.0
    Win32 Version: 2.1.3.0
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Vixen.exe
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    fmod
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/fmod.DLL
    AnalogSpectrum
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/AnalogSpectrum.DLL
    CometConversion
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/CometConversion.DLL
    DMXAddIn
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/DMXAddIn.DLL
    MIDIReader
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/MIDIReader.DLL
    Prop1SeqGen
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Prop1SeqGen.DLL
    Prop2SeqGen
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Prop2SeqGen.DLL
    RemoteClient
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/RemoteClient.DLL
    RGBLEDAddIn
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/RGBLEDAddIn.DLL
    Spectrum
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Spectrum.DLL
    WattMeter
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/WattMeter.DLL
    Waveform
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Waveform.DLL
    LedTriksUI
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/LedTriksUI.DLL
    LedTriksUtil
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/Output/LedTriksUtil.DLL
    StandardScript
    Assembly Version: 2.1.1.0
    Win32 Version: 2.1.1.0
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/StandardScript.DLL
    ScriptEngine
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/ScriptEngine.DLL
    StandardSequence
    Assembly Version: 2.0.8.0
    Win32 Version: 2.0.8.0
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/StandardSequence.DLL
    TriggerResponse
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/TriggerResponse.DLL
    AppUpdate
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AppUpdate.DLL
    ICSharpCode.SharpZipLib
    Assembly Version: 0.85.1.271
    Win32 Version: 0.85.1.271
    CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/ICSharpCode.SharpZipLib.DLL
    System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Feb 2008
    Warminster, PA
    1,298
    Default Re: Need help
    When you reloaded did you install .NET?
    Plainview, Mn
    1,073
    Quote Originally Posted by ctmal View Post
    It would appear not
    HA, somebody else is putting up my lights this year.
    Just tried to reinstalled .net Didn't seem to fix anything. I can open other sequence files. Just not the one that was opened when my computer crashed.
    Thanks for your help
    Ahwatukee (Phoenix), AZ
    1,994
    Scratching my head on this one - but - what version of vixen did you create the songs in?
    Jul 2009
    Kansas City, KS
    182
    Maybe the sequence file could have been partially corrupted during the system crash?
    Quote Originally Posted by wilsonDK View Post
    Unfortunately that error line makes me think that it is not a Vixen glitch causing the error, but instead an XML parsing error resulting from a stray 0x0 (null) byte inside your sequence file. Null bytes are not supposed to find their way into XML based files, unless the system crash affected the file contents maybe.
