I was working on a project for halloween. Needless to say that my computer crashed. When
I went back to working, vixen wouldn't work anymore. I then proceeded to reload. Now I get this message when I try to open my sequence.
If anyone can point me in the right direction to fix this i would be very happy.
Thank you in advance.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Xml.XmlException: '.', hexadecimal value 0x00, is an invalid character. Line 139, position 515657.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowInvalidChar(Int3 2 pos, Char invChar)
at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
at System.Xml.XmlTextReaderImpl.ParseText()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at Vixen.EventSequence..ctor(String fileName)
at StandardSequence.StandardSequence.Open(String filePath)
at Vixen.Form1.OpenSequence(String fileName)
at Vixen.Form1.openALightingProgramToolStripMenuItem_ Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.190 (QFE.050727-1900)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Vixen
Assembly Version: 2.1.3.0
Win32 Version: 2.1.3.0
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Vixen.exe
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
fmod
Assembly Version: 2.1.0.0
Win32 Version: 2.1.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/fmod.DLL
AnalogSpectrum
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/AnalogSpectrum.DLL
CometConversion
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/CometConversion.DLL
DMXAddIn
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/DMXAddIn.DLL
MIDIReader
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/MIDIReader.DLL
Prop1SeqGen
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Prop1SeqGen.DLL
Prop2SeqGen
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Prop2SeqGen.DLL
RemoteClient
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/RemoteClient.DLL
RGBLEDAddIn
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/RGBLEDAddIn.DLL
Spectrum
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Spectrum.DLL
WattMeter
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/WattMeter.DLL
Waveform
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AddIns/Waveform.DLL
LedTriksUI
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/LedTriksUI.DLL
LedTriksUtil
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/Output/LedTriksUtil.DLL
StandardScript
Assembly Version: 2.1.1.0
Win32 Version: 2.1.1.0
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/StandardScript.DLL
ScriptEngine
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/ScriptEngine.DLL
StandardSequence
Assembly Version: 2.0.8.0
Win32 Version: 2.0.8.0
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/StandardSequence.DLL
TriggerResponse
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/Plugins/UI/TriggerResponse.DLL
AppUpdate
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/AppUpdate.DLL
ICSharpCode.SharpZipLib
Assembly Version: 0.85.1.271
Win32 Version: 0.85.1.271
CodeBase: file:///C:/Documents%20and%20Settings/Derek/Desktop/Halloween/Documents/Vixen%202.1.1.0/Vixen%202.1.1.0/ICSharpCode.SharpZipLib.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
