Page 8 of 8 FirstFirst ... 678
Results 71 to 73 of 73
Thread: Convert text to Ledtriks format
  1. #71
    Sacramento, CA
    353
    Default Re: Convert text to Ledtriks format
    Quote Originally Posted by mheuer View Post
    There is only one thing that has to be installed for this to work. After that, the program does the rest of the work.
    Go to http://sourceforge.net/projects/gtk-win/ and run the quick and simple installation program.
    Gtk is open source and safe.
    I was going to package Gtk runtime with the program, but I figured it would make too large to post as an attachment here.
    It also does support changing the size configuration of your panels (1x1, 2x1, 2x2, etc.)
    [EDIT] The 'virtual' LedTriks preview drawing code is still a little crude, so drawing larger panels takes a little more CPU.
    Included with the program is a small ReadMe file, and a couple example images.
    It doesn't support user-definable color 'thresholds' yet, but that is planned.
    Here is the program. It is still a little buggy yet.
    The .zip file needs to be unpacked before running.
    I have not built my LedTriks yet , so please let me know if a feature could be done better or different. It has no 'Undo' feature yet, and make sure you have backups of your sequences somewhere.
    Thanks!
    Does anyone still have a copy of the file from this older post? Looks like the 'LedTricks.zip' file has gone missing. Original post here.
    Matt Stemple
  2. #72
    Houston, TX (near Katy)
    841
    I've changed a couple things that I think may have been the source of the problem, but I'm not sure.
    Here is the new version.
    Let me know how it works.
    Thanks!
    Hi,
    Does anyone have this image tool?
    That's a feature not a bug.
    There's no charge for that.
  3. #73
    Jul 2009
    Kansas City, KS
    196
    Quote Originally Posted by Keith R View Post
    Hi,
    Yep, here's a copy in this post:
    http://doityourselfchristmas.com/for...927#post214927
    To run it you'll also need to install GTK+, the toolkit this program is based on:
    If you get an error about missing libxml2, copy the libxml2.dll i've attached below into the same folder as litfr.exe, and that should solve it.
    Admittedly, the original image import feature itself is pretty rough though, due to the LedTrik's resolution constraints/lack of dimming.
    However, in the version I linked frankr added a lot of features that make it neat for general LedTriks sequencing.
    Attached Files Attached Files
