This is a bit late in the discussion, and I may be commenting more on Jonathon's comments than on the reality that people encounter using his tool, but...
You are not going to get anywhere near 10 ms accuracy in the timing of any AC-based lights using serial communications. In fact, I think that you would be lucky to get 25 ms accuracy. First, the controllers only change the intensity of the lights every half-power-line cycle (8.33 ms in North America). Second, you can't really control which half-cycle a given change in intensity will happen, because the data packets sent out by the computer are not synchronized to the power line, which means that the data in various parts of a given packet may affect the output lights on different half-cycle periods. There are a lot of other effects in the computer that will introduce variable delays and jitter into both the audio and visual outputs...it would take a lot more design effort (and possibly system cost) to get things more precise than around 25 ms.
