Thread: Tunecast II mod. gone bad!
    Concord, North Carolina, USA
    193
    Default Tunecast II mod. gone bad!
    Tunecast II mod. gone bad! While re-mod-ing my transmitter for more range with coax, the solder points on the board pulled loose. Apparently the stiffness of the coax caused the attenuator points to loosen. Does anyone know of another point to solder to for the antenna?
    Take what you can, give nothing back!
    2010 - First Attack - Success!
    2011 - Survived Second Attack!
    2012 - In Total Control
    http://www.dreamweaverholidaylights.com/
    193
    Default Re: Tunecast II mod. gone bad!
    Hard to believe old Jack's dead in the water and no help in sight!
    Kennesaw GA.
    495
    The code says those who fall behind are left behind, But I'm not a pirate, so I'll throw you a line. It's probably best to start over with a new unit. Just watch the temperature of your iron, and the length of time that you soldier. It will cause the traces to pull up.
    Life is a tragedy for those who feel and a comedy for those who think.
    .../___.
    (o_!_/o)
    Check out my 2011 videos http://vimeo.com/user2762767/videos
