Results 11 to 20 of 38
Thread: Metal-free mini tree
    9,215
    Default Re: Metal-free mini tree
    Of the "Christmas in Plymouth" site? I've been by his house a few times -- it's not that far from my house -- but I've actually not met him yet! (They don't let me out of the house very often -- even since I overdosed on burning flux during a marathon soldering nite... ;) )
    I'm a pretty busy guy and between all the music I have to sing, church duties and my software company, coupled with late-nights with the soldering iron, I have almost zero time left.
    But I'm hopeful -- sometime this winter I hope to get a chance to chat with him.
    http://digwdf.com/store/
    Jul 2009
    Ingalls, indiana
    34
    I Live in Indiana so i haven't met him, but Ive talked to him a lot over at PC. He was one of the first guys to help me out. I have really enjoyed seeing his pictures of the display. I enjoy Christ centered displays.
    Dec 2008
    michigan
    207
    thanks for this thread dirk, i finally built something that will blink and flash.
    what pvc are you using? the only half inch i can find is schedule 40, and a 5/8 dowel will not fit inside.
    9,215
    Quote Originally Posted by cmitcham View Post
    I bought all the stuff at Loew's.
    The vertical struts were 1/2" Silver-Line PVC-1120 SDR-13.5 Pr.315pso. It's pure white and the Lowe's SKU# is 717141340512. This is the one that the 5/8" dowel fits inside. It has a thinner wall that normal PVC, and if you measure its outside diameter, it's actually 7/8" with an inside diameter of 11/16".
    The hoop base, curiously enough, is also called 1/2" CTS CPVC 4120 Hi TEMP, 100PSI. It's cream colored and has a barcode on it that says its part # 038561599959, is quite flexible and easy to form into a loop. It has an outside diameter of 5/8" and an inside diameter just shy of 1/2".
    So while "both" have 1/2" printed on them, the cream colored hoop base actually will fit inside the other one!!! I have no idea how they measure this stuff or how they keep it straight! :roll:
    Oct 2009
    N.E. Ohio
    190
    I made my trees almost identical to yours funny enough lol. http://doityourselfchristmas.com/for...ead.php?t=8522
    I also used that cream colored CPEX flex pipe for the base the first time around. This year though when I went to build 4 more treea to add on, I found a cheaper way. Instead of the CPEX at @$4 for 10 ft sections, I found some black flex water line thats the same size and appears to have about the same strength/flex abilities. Its was only around $16 I think for a 100 ft roll.
    Yuma, AZ
    1,600
    Hi:
    As if I didn't have enough to do already, I have been considering some arches. Do you think the PVC you used for the hoop base would also serve for the arches? I guess the real question is: is it strong enough to support the llights?
    I may not do this, I have a lot to go, but having read some threads about arches and bending PVC, etc, this material might work very well.
    [B][I][U]Idun[/U][/I][/B]
    [IMG]http://www.vixenlights.com/sig/sig_h.php/152/136.gif[/IMG]
    [B]Lotsa' Patience![/B] (Some days you can't win, the others you lose, and forget about the rest)
    [B]Some mornings I wake up GRUMPY and other days I let her sleep![/B]
    9,215
    Quote Originally Posted by IdunBenhad View Post
    Hi:
    If the arches are short and close to the ground, the thin stuff may work okay. It's a bit flexible though, and the taller the arch would be, the less structural integrity it'd have and I'd think that wind could blow it around pretty easily. The only reason I used it for the hoop base was because it bent easily and it would be pinned to the ground to hold the tree down.
    2,192
    Dave:
    What are you using to "pin" these to the ground? I have some stakes that came with a commercial tree that I use that are great, but I'm going to have more mini-trees than stakes this year.
    Thanks.
    \dmc
    ________________________
    9,215
    Quote Originally Posted by dmcole View Post
    Dave:
    Thanks.
    \dmc
    I use some cheap garden stakes. They're galvanized metal but because the base is PVC there aren't any GFCI issues. I think they're originally for installing garden edging. Really cheap as I recall...
    Dec 2008
    3,923
    I take a 15" scrap piece of 1/2 PVC Conduit. I cut the end at angle to create a point. I then heat and bend a loose hook on the end. They work great and they are essentially free. After building last years displays, I proably had 40 ft of scrap 1/2" Grey PVC.
