Here is the response from Digi:
The receptacles used on Digi development boards are manufactured by Century Interconnect. Several other manufacturers provide comparable mounting solutions; however, Digi currently uses the following receptacles: • Through-hole single-row receptacles - Samtec P/N: MMS-110-01-L-SV (or equivalent) • Surface-mount double-row receptacles - Century Interconnect P/N: CPRMSL20-D-0-1 (or equivalent) • Surface-mount single-row receptacles - Samtec P/N: SMM-110-02-SM-S Digi also recommends printing an outline of the module on the board to indicate the orientation the module should be mounted.
I found the Samtec connector (since it is through-hole) on Digi-Key:
http://search.digikey.com/scripts/Dk...=SAM1230-10-ND
Not sure if this one will be better or not - might be worth it to buy a set and compare. I'm willing to get a pair just to see if they are better.
Brian
