Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Build Questions
    Philadelphia Suburb
    877
    Default Build Questions
    Let's start this thread so we can all help walk each other through the build. Let's try to keep all questions and answers in one place....
    Lou
    Jul 2008
    3,208
    Default Re: Build Questions
    Great Idea Lou!
    Indiana
    1,196
    Watch out on the resistors - the 750 Ω is very similar to the 150 Ω, and easy to switch, as they are 1/4 watt, and very small. I recommend, when you lay out your resistors, meter them.
    R
    Philadelphia Suburb
    877
    If you open the field bag, I believe you can tell the difference by the amount, there are more of one than the other...
    Lou
    Indiana
    1,196
    I also talked with David (Firegod), about the resistors required, on the SSROz'. If you use the LED's, on the Field Modules, you have to use 510 Ω resistors on the SSR's, for the triac gate, due to the voltage drop across the LED's. I was NOT looking forward to changing out a bunch of resistors, nor was I happy with having two different SSR's, one with 510 Ω, the other with 750 Ω. David suggested using a 6 volt regulator, instead of a 5 volt, and I wouldn't have to change out the resistors. I have several on order, and will be using them. This is the Mouser page for the ones he told me to use:
    6 Volt regulator
    R
    Indiana
    1,196
    Quote Originally Posted by lbro View Post
    There are 4 of the 150 Ω and one of the 750 Ω. I'm just saying that they are very small, and the color code for 750 and 150, is very close, violet-green-brown, and brown-green-brown. It's hard to distinguish between the violet and brown, due to size. You don't have to meter out the brown-red-red's, they are very apparent. Just meter out the 5 until you hit the one 750...
    R
    Indiana
    1,196
    OK, PC Interfaces done...here's the order I found works great...YMMV, as everyone has their preferences, but for somebody who doesn't...I am taking pictures as I go, each step, in the hopes of making, or somebody making a Wiki for the FireGod, if there's interest.
    1. Resistors - all
    2. Zener Diode
    3. Diodes
    4. Sockets
    5. Caps C1-4, C6
    6. Cap C7
    7. DB Connector
    8. Power Jack (same time as DB Connector)
    9. RJ45 Jacks
    10. Cap C5
    11. Voltage Regulator and Heat Sink
    http://crbest.com/vixenlogo02.jpg
    Roger Phillips
    Oxford, IN
    256 channels of blinkin', dimmin' bliss...
    "The road goes on forever, and the party never ends!! Robert Earl Keen
    Just south of Portland Oregon
    794
    Quote Originally Posted by 51fordf2 View Post
    I'm interested and . . . pictures are good.
    Christmas, Christmas, Christ. I don't put lights on my house for ANY other reason than to glorify him. He preaches compassion and forgiveness.
    Jul 2008
    3,208
    1. Resistors - all
    2. Zener Diode
    3. Diodes
    4. Sockets
    5. Caps C1-4, C6
    6. Cap C7
    7. DB Connector
    9. RJ45 Jacks
    10. Cap C5
    hehehehe
    Looks like getting to build mine later will be a GOOD THING!
    Indiana
    1,196
    David suggested putting C7 in after mounting the voltage regulator and heatsink, so you can get to the screw easier, but I always mount the regulator to the heatsink first, tighten it, then mount it as a unit. Easier for me, but personal choice. I'll give both in the construction article. I have both interfaces done, and 4 field modules done. I should be ready to look at getting the PICs programmed soon. Need to start from scratch, on those. Oh goody, something new to learn (and buy!!).
    More to follow...
    R
