Results 1 to 5 of 5
Thread: pics with diag code
    Jun 2008
    elizabethtown, ky
    65
    Question pics with diag code
    is it possible to mix pics with diagnostic code with pics that do not have the diagnostic code? I am populating my ren 64 xc with the chips and am getting them from two different people. Is the combination of pics a bad thing? will it still work?
    _____________________________________________
    Jason "neophaetr" Lamont
    First Year Renard 64 XC
    Spencer Iowa
    1,084
    Default Re: pics with diag code
    A pic with the diagnostic code does not pass the signal on.
    You can have regular redard PICs before it but no chip after the diagnostic will receive a signal.
    JOel
    If I no longer count channels... but instead say I have over 12 universes... Is that too many
    1,746
    Quote Originally Posted by jrock64 View Post
    I haven't tried it, but you could probably connect a diagnostic PIC in "parallel" with a regular PIC. That is, run the output from the previous PIC to the input on both the diagnostic PIC and through a jumper to the next non-diagnostic PIC that comes after it in the chain. You'd be short 8 channels at the end of the Ren 64, but at least the signal would get passed along to what follows the diagnostic PIC by hopping over it.
    don
    Click for display details >>
    Plainview, Mn
    1,073
    Quote Originally Posted by neophaetr View Post
    Short answer No & Yes
    The diagnostic firmware is not for running sequences from vixen. It is to test the circut board.
    It is designed to put in the first PIC postition for whatever board you are building.
    in this WIKI link go to the bottom of the page and it will describe how to use the firmware.
    I can't imagine that anyone supplying you parts would give you multiple PIC's with diagnostic firmware. When I sold some parts I recomended getting one with diagnostic and the rest with PWM.
    You may be confused and getting some programmed with PWM and some with Non PWM firmware. I think that would work, it just would not dim LED's on the non PWM channels?
    This is one more example of why anyone spending the money to build a Renard should also spend the money for a PIC programmer.
    HA, somebody else is putting up my lights this year.
    Mooresville, NC
    5,069
    Quote Originally Posted by bmcgeeny View Post
    1. You may be confused and getting some programmed with PWM and some with Non PWM firmware. I think that would work, it just would not dim LED's on the non PWM channels?
    2. This is one more example of why anyone spending the money to build a Renard should also spend the money for a PIC programmer.
    1..Yes, that can be done with no problems. I have several PICs in my boards that are PWM to run my strobes and the rest are non-PWM.
    2.. Couldn't agree more!
