Results 1 to 10 of 25
Thread: Streel Light
    Default Streel Light
    I don't know if any of you have had to deal with this, but I have a street light in the corner of my front yard.
    Up until now, I thought it was a great thing to have. Free light.
    Has anybody else had to deal with "turning out the light"?
    I really don't want to have it on when I am running the display. It is quite bright.
    I did remove the access cover - and there is an inline fuse inside.
    Should I remove the fuse, or will I be asking for trouble?
    Sep 2007
    Isle of Wight, England
    15
    Default
    I have one just alittle bit up from my place, 2 years ago it was fine but they before last Christmas my neighbours cut their 80ft tree down!!!!! now its a little more of a problem but I just work around it and put stuff that needs to light up near it.!!
    I wouldnt go putting your hands in a street light, I know over here in the UK its a rather large about of power going through them and my grandad used to work on them and has seen one of his mates die from them so best just top put up I would say.
    "Wighting up the Island" - http://christmas.astro-space.net
    Apple Valley, MN
    3,220
    Default
    I know of one person that contacts the city and has theirs turned off during the lighting season. He calls to tell them when it’s time to turn it back on.
    I know of another person that climbs the pole and mounts a C7 bulb next to the sensor and dedicates one control output to this light. This way he can turn the light off during the show and back on when it’s done.
    Sep 2007
    15
    Default
    now I like that last idea!!
    Default
    What would I need to do to make a "normaly closed" ssr and wire that up to it. hehehe
    Madison, WI
    193
    Default
    Consider as small of a flashlight bulb as will trigger the photo eye on the street light. Run some wires in duct tape to match the pole, down to a box taped to the pole a little off the ground so a ladder is needed to switch it on/off. Get twice as many rechargable AA batteries that are needed to power the bulb for the length of the show and just switch, the batteries each night. Always have one set recharging. That way you can hide it on the pole and there are no wires going anywhere.
    WARNING: DO THIS AT YOUR OWN RISK.
    Another option might be to shine a laser at the sensor if you can get it aimed at it.
    - Michael
    Maple Shade, New Jersey
    908
    Default
    Quote Originally Posted by Slush
    First off, I work for the power company. Tampering with the light will result in penalties if it is discovered (mainly by someone complaining that the light isn't working) They do pursue charges just to make a point. In addition to this, the power company usually isn't willing to turn it off to help enhance your display. Regardless of how bright your display is, the street light is there for safety and to deter crime. It is contracted by the township for those reasons. Turning it off intentionally has liability issues for you, the power company and the township. So it's an all arround bad idea to disable it.
    I have read on Planet Christmas that someone was able to get the light turned off. It wouldn't happen to lights provided by our company. The policy is: the lights are there for a reason.
    All that being said, I have one of them across the street from my display. It's very large and very bright. I put together a way to turn it off remotely without tampering (directly) with it. I took an X-10 lamp module that has a lamp socket built into it. I screwed it into a pigtail lamp socket that I connected to a long piece of SPT1. I put a small 40watt bulb in it and placed it near the photo cell of the street light (not going into much detail about how this was done...) and ran the SPT to the tree in the front corner of my yard. Use X-10 to turn the light on, and within 30 seconds or so the streeet light was out.
    Lasty, I used this one time and got paranoid. Even with the street light on my display outshined it by a long shot. I asked my neighbors if it was taking away from the display and hinted there was something I could do about it if it was. They all said it had little or no effect on the way the display looks. Besides, it lights up the street for drivers and people walking around.
    I'm not putting my little toy back up on the light this year. I don't think it's necessary, or worth the risk.
    Jeff
    "I have blah blah lighting software, so person come help!"
    Mooresville, NC
    5,184
    Default
    I have the exact same issue. The light is one that I requested to have placed on my property and I pay a monthly flat rate for it.
    My plan to turn it off is with a night light and a timer. I made a adjustable fixture to place it on the light with a couple heavy duty hose clamps. Just need a bucket truck now.
    Below is a couple pics.
    Central (like the actual center) PA , USA
    378
    Default
    Quote Originally Posted by ErnieHorning
    I don't have streetlights but the whole neighborhood has yard pole lights (with photosensors). I turn mine off using a light string on the pole.
    Of course this isn't a city owned light.
    Tony
    There are 10 types of people in the world. Those that understand binary, those that don't and some who know Gray encoding.
    Aug 2007
    Little Rock, Arkansas
    31
    Default Re: Streel Light
    If you touch the fuse you may get electrocuted. Here's an idea that may work for you without any danger of getting electrocuted or getting in trouble. There are shields that are made for streetlights for people who have a window(s) facing in such a way that they are bothered by the light. Call your power company and ask them to come put one on the streetlight. Sometimes they are provided for free.
    TED
