Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 72
Thread: 2.1 Tentative
    81
    Default Re: 2.1 Tentative
    Much like Steve's experience, I copied sequences, profiles, and programs and everything fired right up. From the scheduler I'm running a program using a profile, than repeating a sequence with a profile and then one without each for 90 minutes and I'll repeat that daily until I break it or the snow melts and I can take down my display - whichever happens first.
    MR16s look good under the snow.
    Thanks KC
    Spokane, WA, USA
    685
    Quote Originally Posted by Aurbo99 View Post
    Only thing I can note is a request to disable the Programs >Manage button while "Executing Timer Control" routine is running.
    Nothing can be done with Vixen until the current Executing Timer Control runs its course, or you crash Vixen from the Control Panel.
    That's fair and reasonable. What else have you done that crashes the app while a scheduled execution is running?
    Dickson City, PA
    509
    Thumbs up Re: 2.1 Tentative
    Downloaded 2.1, copied audio/sequences/profiles, made a new program, set a timer.
    It started on time, and is still running.
    I had no problems with timers, background music, or any issues with anything this season. I can't confirm any fixes, but I can say it still works!!
    tom
    Zaker
    1 - Ren 64
    4 - Ren 24
    1 - Ren48LSD
    2 - E681
    LOTS OF LIGHTS!!
    [URL]http://lights.quietwebhosting.com[/URL]
    Alexandria, VA
    162
    I am confused. I downloaded 2.1, extracted the zip file, went to the folder where everything was extracted, opened it up, and cannot find a setup.exe, install.exe or vixen.exe in the directory. All I can find is Prepare.exe and update.exe. I think prepare converts old files and update is just the script that runs when you start vixen.
    Which am I supposed to click on or what did I forget to do? Thanks in advance for any help.
    Steve
    Spokane, WA, USA
    685
    No vixen.exe? Try downloading it again, it should be in there.
    1,177
    Quote Originally Posted by scharbon View Post
    Steve
    If there is another subfolder named "Vixen 2.1", keep opening them. Like the spaghetti sauce...it's in there.
    Yuma, AZ
    1,600
    Hi KC
    I'm a "new one", so I may have the problems. I'm still learning.
    This error occurs on sequence startup (F5):
    Plugins:
    Adjustable Preview
    Renard Dimmer (modified)
    32 channels (1-32)
    Serial Port==Com 2
    8 data bits
    No Parity
    1 Stop Bit
    Following dialog box opens:
    Vixen Error:
    (Router-Startup)
    Insufficient system resources exist to complete the requested service
    Sequence continues normally after pressing OK in dialog box.
    I do not have the Renards connected (they are not constructed yet).
    This dialog did not appear until using Tentative 2.1.
    The sequence (unfinished) ran OK on 2.09. However, going back to 2.09 after the error with 2.1 results in the same error without a restart of the computer.
    Also, the computer restarts itself from a shutdown command, but only after using Tentative 2.1.
    Further testing will be done to see if it's my problem.
    Computer:
    AMD Athlon 64--2.0 Ghz.
    2.0 GB memory
    2 monitors
    Windows XP Home Edition
    Thanks for your work. Would like to see recognition of USB ports in Parallel plugins.
    Again, THANKS
    Idunbenhad
    Ontario, Canada
    2,140
    Quote Originally Posted by KC View Post
    So far this is the only area I've encountered this problem KC
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Alexandria, VA
    162
    Thanks all,
    I got the files finally. After KC told me to download it again, I checked the Zip files and they were in there - they just never extracted (about 4 files failed to extract). Extracted again and got it to work.
    KC, thanks for the change to the script sequences that allow lights to stay on between commands. Makes it very useful for how I intend to use the scripts.
    Steve
    Spokane, WA, USA
    685
    Things have been quiet. Is it really going that well or is everyone as busy as everyone seems to be these days?
