Results 1 to 7 of 7
Thread: XLights FPP Connect Fail
    Aug 2023
    38
    Default XLights FPP Connect Fail
    I'm trying to export a sequence using FPP connect in Xlights and I keep get the spinning wheel of death and have to force quit the program. I'm just trying to get a simple 90 second sequence to my F16v4 to test have something out there for Halloween.
    I'm using just the Falcon v4 with no pi and running Xlights on a mac.
    171
    Default Re: XLights FPP Connect Fail
    Is the controller online according to xlights? Can you ping it?
    Aug 2023
    38
    Excellent question. I may need some talking through on this one. On the controller details it states active and there is a green dot in the lower right. What else should I be looking for to ensure it is active?
    I am plugging along with YouTube and the forums to figure out what the heck I’m doing, so I wouldn’t be surprised if I jacked something up.
    Feb 2022
    Arlington Heights, Illinois
    66
    Assuming you have an SD card in the falcon, have you gone into settings and formatted it?
    Aug 2023
    38
    I do have a 64GB SD card in it and I formatted it prior to installing. I didn't see an option to format it through the UI, but I'll check again.
    I just double checked everything, setup the visualizer, had a successful upload to output, but I still cant get FPP connect to work. It just processes endlessly without any fault messages. I also can't get the lights to test through Xlights. They have all been tested through the Falcon so I'm not worried about that.
    Update, the xlights zoom geniuses were able to fix my problem.
    171
    We're you able to follow along? What was the fix?
    Aug 2023
    38
    I was, those guys are super knowledgeable. A combination of configurations with the controller itself and changing from E131 to DPP, v2 uncompressed, and then some output settings and then changing my show directories folder location.
    In short. I have no idea, but it worked
    They also highly recommended adding a pi instead of running everything off of the falcon.
