Thread: Wiring up power F16V4 to Two expansion with 6 power supply
    Sep 2023
    2
    Default Wiring up power F16V4 to Two expansion with 6 power supply
    Hi everyone,
    First time wiring up and not seeing many videos that goes into detail but am wondering if someone can tell me if my assumption is correct.
    So if I have 6 power supplies, and been reading that I should do two plugs. Do I just wire up one power supply to the plug and do jumper to the other 2 power supply? and repeat for the other 3?
    Last since I have an F16V4 to two expansion board do I just connect one power supply to each power input? Since the 3 boards would have 2 on each side, would 1 power supply go to each do? Please let me know if I'm missing anything. I don't want to mess anything up.
    Thanks!
    152
    Default Re: Wiring up power F16V4 to Two expansion with 6 power supply
    Yes, you can jumper all the power supplies up to the limit of the wire/circuit you are using.
    You can power the boards from one or more power supplies up to the wire or circuit board limits within the range of the power supply.
    In your case, three PS jumpered together and one PS powering one side of each board makes a lot of sense.
    Sep 2023
    2
    Thank you so much!
