Thread: Lrs-350-12
    Brownsville, TX
    1,220
    Default Lrs-350-12
    The Meanwell LRS-350-12 power supply states that it has an output of 29 amps. I noticed that there are 3 grounds and 3 V positives. Are the 29 amps spread between these on a separate rail or are they all on the same rail and the several inputs are to try reduce clumping up on hookups?
    2010 Plan: Hoping to maybe break the 100 channel marker.
    2011 Plan: Finally hitting 116 channels!
    6,269
    Default Re: Lrs-350-12
    In essence, you have three outputs that are bussed together. The max aggregate current over the three is 29A. I do not know what the max rated current per terminal is, but looking at the board, it looks like you should easily get 25A out of a single terminal. The spec says nothing about the per terminal rating.
    Brownsville, TX
    1,220
    Thank you! You have verified what I was thinking was the case.
    Mike
