The problem is, you need an ESP32 to get access to Ethernet. The ESP8266 does not have enough pins to make it work. ESPixelStick V4 DOES support ethernet.
Is there away to run a ESPixelStick v3 off a ethernet cable and not wifi. If so how?
Not sure about running my show with wifi. I use my pixelstick as standalone props and thinking I would like too use one of them to work about 105 ws2811 pixels on another display prop.
Thanks for any help I can get
Tony
I assume an Arduino Uno running ethernet shield wouldn't work.
