Re: Radial Alum. Cap. Substitution
The voltage on a cap is the max rating. You can substitute higher, but depending on how it is in the circuit, lower is not advisable. Is the 50v called for on the BOM, possibly that was the part available and used. Someone with experience building that particular board should be able to tell you if it's ok with the lower voltage. I may be wrong but there shouldn't be possibly more than 12v on that board.
Zaker
1 - Ren 64
4 - Ren 24
1 - Ren48LSD
2 - E681
LOTS OF LIGHTS!!
[URL]http://lights.quietwebhosting.com[/URL]
