Results 1 to 4 of 4
Thread: configuring dig quad outputs
    Nov 2021
    30
    Default configuring dig quad outputs
    been a while since ive been on here ive been running arduino with 32 ac channels for the last couple years they work great thanks to this group it seems im in need of a litte more guidence. ive been trying to add my digquad to vixin i can successfully ad it and i can add multiple universes and make them work ,what i cant get to work is all four outputs i have 200 pixels on pin 1 set into 2 universes that work fine but when i try to add more and use pin 2 i cant figure out how to get pin 2 3 or 4 to show up in my controller list thanks guys
    6,164
    Default Re: configuring dig quad outputs
    They never will. Lets say you have 200 pixels on each port. Forget the universes, they are a useless issue that confuses things. Vixen will see the Dig as an 800 channel E1.31 controller. You then configure the E131 to send the 800 channels in as few universes as possible. Then on the Dig you configure your four ports. On Vixen you patch your props to the appropriate channels in the monolithic channel list for the e131 controller.
    Nov 2021
    30
    Thanks Martin I think I understand I will try when I get home this evening and I’ll post my results
    Nov 2021
    30
    thank you again martin you were a big help to me on my arduino project and again on this project . i was over complicating it your explaination was great and easy to understand worked flawlessly i do have a few other questions but im going to search the fourm first and if i dont find my answers ill post in the fourm thank you
