Results 1 to 5 of 5
Thread: LED Panels / LED TV's
    Dec 2018
    8
    Default LED Panels / LED TV's
    I'm considering putting up a panel or TV on this blank wall. It's a Sunday school room and I'd like to do, well, I'm not sure with them! I know there's got to be some really neat displays I could create on either. But I don't fully understand the capabilities, limitations, pros & cons for each. If anyone has an opinion on either, or can point me to a link that explains more, I'd greatly appreciate it. Thanks!
    Jan 2018
    Saratoga Springs, UT
    93
    Default Re: LED Panels / LED TV's
    One important question for you is- what is the main intention for use? This will determine what equipment you will need.
    6,137
    A TV with an RPI would be the most versatile instalation.
    May 2016
    397
    A full wall of LED panels? Did it. I documented it here: https://falconchristmas.com/forum/in...?topic=12957.0
    The FPP guys were decent enough to build support specifically for it, and that’s now part of the current FPP build.
    Candidly, though, the viewing distance is insufficient for LED panels to look good.
    Dec 2018
    8
    That's a good question!!! Scrolling messages, use in a Christmas type display. I honestly don't have a set idea. But I've seen them on larger outdoor Christmas displays that I'd liek to bring it indoors but obviously on a smaller scale.
