Thread: Connector Connundrum
    173
    Default Connector Connundrum
    I've used a lot of diyledexpress pixels and connectors in the past. No problem.
    The issue I have now is that I have some items that I acquired a year ago and I don't recall the source. The pixel strings are Holidaycoro connectors. The controller has pigtails that look close-but-not-quite. The attached picture shows male holiday coro connector on the right, and the female from the controller on the left. The pins seem to be the same size/shape, but the plastic won't allow them to connect.
    It's certainly cheaper to replace pigtails than strings of lights. Can anyone identify these - specifically the connector on the left.
    114
    Default Re: Connector Connundrum
    I'm pretty sure that Holiday Coro connectors are similar/compatible with X-Connect
    https://www.wiredwatts.com/learn-connectors
    Some of the vendors have adapters to go between, or you can always make your own:
    https://www.wiredwatts.com/xchangers
    https://RudolphSearch.com - Making it easier to find info across the Christmas Light forums!
    Nov 2010
    Manhattan Kansas
    371
    Wiredwatts has a good page on the different connectors
