Re: No Pixels Lighting on E682
Looks like you have 3 strings of 50 pixels set up on universe 11 on three different ports. 1-1, 2-4, and 4-1. If this is correct, good. You also have the red (brown wire) into V+. Double check that the 5 volt IN on the pixel is the red wire. Make sure it says 5 volt IN. It looks correct. If running 5 volts, make sure the jumper is on 2-3. I can't see if it is from the picture. Also make sure your URL is correct. If something else has DHCP to the same address, it could cause problems.
That's a feature not a bug.
There's no charge for that.
