I'm really fighting this transmitter off of the K16A-B kulp controller this year. Last year I was able to get signal clear down to the end of my street, but this year it is fuzzy in my driveway, and I really don't know what to do. I started with a short piece of 16ga wire (2ft) for the antenna, but then when that wasn't working I switched to a longer (5ft) piece of 16ga wire, and that still isn't doing the trick. I have messed with all the settings in the plugin for the transmitter and I can get it better, but nowhere near what I want. It has a lot of static just in the parking lot across the street which is where most of my viewers would watch from. Would have just thought I needed a more powerful transmitter, but I know what it was capable of last year. Any help would be appreciated.
Current best settings in the plugin are:
Frequency: 98.5 MHz
Power: 115dBuV
Tuning Capacitor: 60
Compression: -15
Audio Gain: 10
(2) Kulp K32A-B
(1)Renard SS16
(1)Renard SS24
(1)EDM-LCD-CS-EP
(20)P10 Panels
(1152) Pixel Boscoyo Matrix
WIKI
Become A Supporting Member
Falcon Christmas
Renard Controllers
Thanks Kev for the tip, I did have my volume at 100, I think this helped slightly, but I still get nothing but static from the street. I'm wondering if the addition of two half trees on either side of my mega tree is causing this. I have my controller right under my mega tree, and now that I have both trees on either side I might be getting too much interference with the signal trying to leave? Has anyone extended the Si4713 from direct mounting to the kulp board and mounted it elsewhere? I'm thinking I could possibly mount it to the top of my mega tree instead?
In case anyone reads this later and wanted to know how things ended up. I think I just had too much interference for the little Si4713 transmitter. I purchased a Retekess TR509 off of Amazon and the difference is impressive. I put the new transmitter in the garage and just ran a long aux cord from my controller to the transmitter, and I can now get range way over the allowable limits of the FCC (up to 1.5 miles!). I had to turn down my output so it wouldn't go so far. I am really happy with this thing, and would recommend anyone just get it instead of fighting with the smaller boards. This will not be outgrown by my future shows.
(2) Kulp K32A-B
(1)Renard SS16
(1)Renard SS24
(1)EDM-LCD-CS-EP
(20)P10 Panels
WIKI
Falcon Christmas
Renard Controllers
